20 Most Recent
RTO Fuel Pump Carburetor Transmission Tester Gauge Tool Questions & Answers
I change my fuel pump in a 1998 acura 3.5rl and
It has a fuel pump relay and fuse. No reset tho. Can you hear the fuel pump kick on? If no than try changing the fuse or it could be other sensors that are not properly placed causing the fuel pump not to work. Another possibility would be putting a bad fuel pump in place of a bad fuel pump. Was the fuel tank cleaned when it was done? If not it could have debris floating around in the fuel pump causing it to do that.
Have a chevy malibu that would not start up, it
basics: spark,fuel,air,compression make an engine run.does it have spark? take a plug out put the wire back on it, ground the body of the plug to metal on engine. have someone crank it over, spark?y-n?yes ok move on to fuel. no, check for spark at the distributor cap.eliminate possible problems one by one.check for fuel flow. take air cleaner off the carb.if carbureated. pump throttle while looking down carb. throat.fuel should squirt into carb below choke plate.{hold it open while looking}fuel? y-n? no: check for fuel flow fron gas line into carb. remove fuel line andcatch fuel from the line in a container while helper cranks engine.no fuel, probably bad fuel pump.etc. good luck
How to replace or change a fuel pump for a 1996
you have to get under the truck and remove the gas tank. be careful removing the lines before you completley remove gas tank. then you can get to the top of the tank and remove the pump and sending unit. they are both held in the same housing
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
