20 Most Recent Brand Remote Start/keyless/car Alarm Very Sleek Questions & Answers
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few for now u can try reliable-store.... let me know if u need help thanks
Brand Remote... • Answered on Feb 16, 2019
hello u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store for free the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Brand Remote... • Answered on Jan 24, 2019
you can try out some guide from reliable-store they also provide live chat feature for instant help and it's very useful using that I fixed my own excavator 5-6 times without any other help plus free so whats harm in not getting
Brand Remote... • Answered on Jan 22, 2019
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Brand Remote... • Answered on Dec 05, 2014
First replaced the batteries, you may find a CR2032 in there easy to replace then try before blaming any other components
Brand Remote... • Answered on Aug 03, 2014
In your local shop - a single AAA is all the Spy 5000m remote fob needs.
Brand Remote... • Answered on Apr 24, 2013
Installations of this nature are usually reserved for professionals. However, get out your installation manual. You will also need two single pulse double throw relays and some diodes. First you will need to locate the ground when running.This wire might be labeled " (-) third ignition". The first relay for the starter will be wired like so: starter wire to 86, fused 12 volts to 87, 30 out to vehicle second starter wire, 85 to ground when running. The second relay will be wired 86 to vehicle ignition, 87 to fused 12 volt, 30 out to second ignition, and 85 to ground when running.
Brand Remote... • Answered on Jan 27, 2013
You need to be more specific if you expect assistance with your problem.
what brand is alarm? hood pin IS required,ground hood pin lead try to remote start If you need further help, I’m available over the phone at https://www.6ya.com/expert/stephen_fa62cb6d50fe05e8
Brand Remote... • Answered on Jan 19, 2013
You need to adjust the tachometer sensing wire, it usually wraps around a spark plug wire so I can sense when the car starts. On my spy alarm, the wire was grey. Hope this helps.
Brand Remote... • Answered on Oct 15, 2012
Brand Remote Start/keyless/car Alarm Very Sleek Logo
Popular Tags
58 questions posted
Top Spy Vehicle Parts & Accessories Experts
tina gallow
Kardoc
Mr.Mike
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Spy Vehicle Parts & Accessories
Most Popular Question
remote start 09 camry installation
  • Vehicle Parts & Accessories
