20 Most Recent Razor E100 Electric Scooters Red Questions & Answers
I had this same issue with the Razor E100. I couldn't even remove the plastic cap it was so recessed. Here's what worked. The value comes from the factory very recessed in. It's so far in it's hard to remove the cap with your fingers. You'll need to get the value loosened up and pushed out a bit. You will do this from the other side of front wheel using the hole. The value can be manipulated slowly to stick out about an inch from the plastic wheel. It takes some time and patience. First, you’ll need to turn the scooter over and rest it on the handle bars and back of the deck. Put a towel or flatten box under it if working on a rough surface to protect the scooter. Then used the supplied Allen wrench or similar object by putting the long end of the wrench into thru the opening hole on the other side of the wheel. Wedge the edge/end of the wrench against the value from the other side of the wheel and push hard to loosen up the value. This takes some time. Do this on both sides of the value and also against the center of the value. It took me about 5 mins of careful pushing. Eventually you will be about the get the value to almost a right angle from the wheel and sticking out about and inch. Then remove the plastic cap. This will give you room to attach a bike pump. I actually had to push the value back in a bit once finished so the wheel could turn freely. It will work, just be patient and forceful. Take your time.
Razor E100... | Answered on Nov 03, 2018
The Switch can be almost any but the lighted switch has to be a compatible 24vdc lighted switch.
As seen on this web page.
SWT-105
Razor E100 and E125 Electric Scooter Parts ElectricScooterParts com
Razor E100... | Answered on Feb 13, 2015
Razzor was purchased by Polaris, contact nearest Polaris dealer
Razor E100... | Answered on Dec 02, 2014
hooperimports.com/showpages.asp?pid=1013
they have wiring diagrams and information on how to wire chinese import engines and for more info contact http://tinyurl.com/m7ghqz
Razor E100... | Answered on Dec 02, 2013
Hi:
I have a rascal 3 wheel chair and the tire is flat on back, how do they come apart for repair, thanks.
Leroy
Razor E100... | Answered on Aug 20, 2011
Razor E100 batteries are easily replaced & there are guides on how to this on razor.com, genuine Razor batteries are available at most good Razor product stockists.
Razor E100... | Answered on Jul 05, 2011
if your gonna write something that can't be answered atleast accept me so i get paid for my time unless you can explain in detail what your problem is
Razor E100... | Answered on Jan 07, 2011
using a Normal bicycle pump
Razor E100... | Answered on Nov 22, 2010
Probably around 12 volts. It depends on what your battery (ies) put out but I thinkit's most likely 12volts.
Razor E100... | Answered on Nov 19, 2010
Blade E scooters are products of China, so you would need to contact the manufacturer to acquire the factory wiring diagram. Usually the manufacturers are very allusive and hard to contact, so if this is the case with your scooters, you can try this online scooter parts store. They have a "find a repair shop" feature that will provide you with addresses and phone numbers of shops near you that will help you.
http://urbanscooters.com/partsforscooters
-Jackson
Razor E100... | Answered on Oct 26, 2010
There are a few components to check when diagnosing electric scooter issues.
1. Batteries
2. Wiring
3. Controller
4. Throttle Assembly
5. Fuses
Once you inspect all of these for damage, you can test your motor and batteries, by bypassing the controller, and directly hooking the batteries to the motor. If the motor spins very fast, then you have good batteries, and a good motor. The controller will need to be replaced. If your motor spins slowly, you could require new batteries or Controller, or battery, depending on the results.
You can find replacement parts and service locator here.
Razor E100... | Answered on Oct 12, 2010
I have the aggressor scooter as well. You don't need and probably will be hard to find the toggle switch you mention. Just go to Radio Shack or Frys with the switch and find the one that match the power rating and profile of the old switch.
Razor E100... | Answered on Aug 18, 2010
Get a replacement holder at the Radio Shack ... you will have to modify to install in all probability.
Razor E100... | Answered on Jul 05, 2010
in order for the scooter to go you must already be walking with the scooter. so hold down the throttle and start to push (kick) the scooter.
Razor E100... | Answered on Jan 31, 2010
Hi Marci. Take the scooters, batteries and all plus your charger to any autozone store and ask them to test your batteries and charger for you. They have the equipment to do these tests and they do it for no charge, they are great.
Razor E100... | Answered on Jul 27, 2009
Razor E100 Electric Scooters Red Logo
30 questions posted
Top Razor Sport & Outdoor - Others Experts
Roy Cunningham
Level 1 Expert
Randy Schumann
Randy Schumann
Tom Chichester
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Razor Sport & Outdoor - Others
Most Popular Question
battery charger always remains green
  • Sport & Outdoor - Others
