20 Most Recent Nordic Track /proform Treadmill Drive/motor Belt 118016 Questions & Answers
Did you ever find out what was wrong? Mine is doing the same.
Nordic Track... | Answered on Oct 14, 2018
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
Nordic Track... | Answered on Oct 12, 2015
You problem is with the motor controller. If everything works but belt want turn 99% of the time it's the motor controller. Call if you'd like more information. 404.456.2327
Nordic Track... | Answered on May 15, 2015
You cant adjust them.You need to replace only.
www.iconservice.com
Nordic Track... | Answered on Nov 12, 2013
see the video how to do it:
God bless you
Nordic Track... | Answered on Jun 13, 2012
Dear Sir:
You must read the instruction manual, or you can call to www.proform, com an get service support online. or go www.iconservice,com and get chat online too, for help.
God bless you
Nordic Track... | Answered on May 14, 2012
Go to www.iconservice.com and Input Nordictrack Pro and you will find a manual for your unit
Nordic Track... | Answered on Dec 06, 2011
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, [email protected]
Nordic Track... | Answered on Mar 28, 2011
there should be two screws one on each side of the belt in the back of the treadmill (you may need to remove the side rails (theres one on each side of the belt) to see them) those screws will tighten the belt. note: you must be carfull that the belt is tightened evenly. livestrong.com is a great website if you need help wih this. good luck!
Nordic Track... | Answered on Mar 02, 2011
Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
67 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
motor belt replacemant nordic track 4500
  • Exercise & Fitness
