20 Most Recent Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill Questions & Answers
Tighten the 2 bolts that attach the hinge to the deck in the right front corner
Nordic Track... | Answered on May 16, 2014
1( Adjust the Reed switch, clean and tight the wires connector very well
see the diagram.
1A) Tight the ribbon cables from keypads very well, and clean
2) Run after you fix it the software calibration for diagnose and troubleshooting, and fix it.
See the block diagram
Nordic Track... | Answered on Jun 14, 2012
if it is moving to the right you must tighten the right side of the rear roller
you are doing wrong side
Nordic Track... | Answered on Mar 29, 2011
Log onto IconService.com and you can download your manual.
hope this helps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nordic Track... | Answered on Nov 04, 2010
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Nordic Track... | Answered on Aug 10, 2010
To select the settings mode, first remove the key from the console. Then, hold down the Stop button while reinserting the key into the console.When the settings mode is selected, the display will show the word ENGLISH or METRIC to indicate which system of measurement is selected. To change the system of measurement, first highlight UNITS and press the User/Enter button. Next, press the increase or decrease button beside the User/Enter button to select the desired system of measurement. Then, press the User/Enter button.To exit the settings mode at any time, remove the key from the console.
Nordic Track... | Answered on May 15, 2010
Please download the User manualf or Nordic track iFit Coach Plus
and see in the user manual, how to do it.
Blessing
[email protected]
cell+whatsAPP:+50588611441
Nordic Track... | Answered on Sep 19, 2020
cleal the contacts relais, and replace if necessary. Of course your LUBE the gear and shaft too.Test the elevation motor for problem bearing for repair.
sincerely. God bless you
Nordic Track... | Answered on Jun 23, 2020
https://www.audiusa.com/content/dam/audiusa/brochures/2019/2019_Audi_Q7_QSG.pdf
Nordic Track... | Answered on Apr 10, 2020
https://www.manualslib.com/manual/583110/Nordictrack-Commerical-2450-Treadmill.html?page=27
Quoting from manual above (may be similar model if not the same.)
7. Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the treadmill is displayed
in a store. While the demo mode is turned on, the
console will function normally when you plug in
the power cord, press the power switch into the
reset position, and insert the key into the console.
However, when you remove the key, the screen will
show a demo presentation.
To turn on or turn off the display demo mode, first
touch the Demo Mode button. Next, touch the On
checkbox or the Off checkbox.
Nordic Track... | Answered on Mar 06, 2020
Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill Logo
14 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
stargajzer
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
change speed from kph mph
  • Exercise & Fitness
