20 Most Recent
Burton 3L Snowboard Pants Optic Del Jaq Black Questions & Answers
What fit is this type of snowboard pants?
Call me crazy but most Snowboard pants as of yet don't have a separate "fit". That means you won't have any described as"loose", "baggy" "straight leg" etc. What you have instead is that snowboarding pants are made w/ space and flex @ the knees and are wide enough for boots @ the ends. Any adjustment to "fit would have to made in choosing what size you planned on wearing. Hence if you wanted em "baggy" get em bigger etc...
8/28/2010 1:54:10 PM •
Burton 3L...
Answered
on Aug 28, 2010
I recently bought a Blunt
The threaded inserts are built into the layers of the snowboard so they can not come out while riding. Imagine if they were able to be pulled out and one came out while you were riding - your boot and binding would lift right off the snowboard. You can try to fix the threads with a tap (threading tool), but otherwise they will not be able to be fixed and you would have to get a new board. If you just bought the board, you could try contacting Burton about having it replaced.
My Burton boots are loose around the ankle and the
For the ankle you may need some specially shaped foam inserted between the boot outer and the liner to take up the space. This can be done at any good snow store. As for the laces make sure that when lace up in the morning lace the boots all the way to the top and when you reach the top, while holding the laces, flex in the boot a few times and kick your heel against the ground to make your your foot in snug (this may also help issue #1. Once you have done this, pull up hard again on the laces and loop them once around the top before tying a double knot.
Boy just got a burton hero board, put on his danny
The Hero is designed to work with Burton's special two bolt system. The base plate on the Burton bindings is much stiffer than standard (like the on the Kass's) so will flex and loosen quickly. The best solution if these were both bought together from a store is return them as they should not have been sold together. If this is not possible then sell the bindings and buy the correct Burton model. If this is not fixed the mounting screws will eventually damage the board and need costly repairs.
Burton bag failed
I doubt it.. At 15 years old it's had a good life.. Time for a new one..
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like
How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
