20 Most Recent Tippmann 98 Custom Act Paintball Gun Questions & Answers
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Tippmann 98... | Answered on May 13, 2017
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Get another ball detente from ebay, this one is the cheapest one I could find.
http://cgi.ebay.com/NEW-TIPPMANN-C-98-BALL-DETENT-A5-BALL-DETENT-/370469346400?pt=LH_DefaultDomain_0&hash=item5641b19c60
Tippmann 98... | Answered on Jun 25, 2016
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
Play hard, play safe, play with honor!
8^)
Tippmann 98... | Answered on Mar 10, 2015
The sear is not catching the bolt and resetting it properly. Or, there is not enough air pressure to push the bolt back to its original position. I would take it to a gunsmith. Parts fly out of a Tippmann if you open it up.
Tippmann 98... | Answered on Feb 17, 2015
First make sure your marker has been fully cleaned out (No paint in the marker).
Always follow the flow of air when a problem like this arises.
Make sure their is nothing blocking the ASA (Where your tank screws into the gun)
If you have a regulator make sure you are not running any lower than 800 PSI, if you have a gas through grip then disregard this step.
First check your hammer o-ring, if it is broken you need to replace it and oil it, if not just oil it. This is the most common reason you would have this problem.
If you did not solve your problem yet than check your sear which holds back the hammer. If it is rounded then the bolt will skip instead of re-cocking the gun. Make sure it is still sharp, if this is your problem you can buy a new sear or file the one you have.
good luck!
Tippmann 98... | Answered on Oct 30, 2014
O-ring. If it is leaking near the tank, it is the o-ring on the tank. Otherwise, it could be one of many o-rings inside the marker. I would take it to a gunsmith and get all the o-rings swapped out.
Tippmann 98... | Answered on Aug 09, 2014
The bore of your barrel is too small for the paint you are using.
There is a velocity adjuster on the left side of the body, just below and to the right of the "N" in "TIPPMANN."
In order to adjust the velocity you need to be in a place where it is safe and legal to fire your marker (paintball field, with all bystanders protected by netting or paintball goggles.) You will need a chronograph and a 3/16-inch hex wrench.
The adjuster is a screw that blocks the gas flow from the valve to the bolt. If you screw it in (clockwise) it blocks more of the gas, so your velocity goes down. If you screw it out (anti-clockwise) it blocks less gas, so the velocity goes up.
Just take a shot over the chronograph to check your velocity, adjust and check again until you get it where you want it. Most paintball fields limit velocity to 285 feet per second. Never go above 300 feet per second, as velocities above that are unsafe (beyond paintball goggle ratings and can cause damage and infection on skin due to the heavy impact.)
It is important to test and adjust the velocity before each day of play, and even multiple times during the day as weather changes, because it is affected by temperature.
**** it and that should stop.
If that persists make sure you have cleaned the marker and used a good paintball oil to lubricate the internals.
At the next level you could have a o-ring that's old, brittle, broken and now is leaking by. Your local airsmith should be able to provide the necessary part(s) or fix it in short order for you.
8^)
Tippmann 98... | Answered on Jul 19, 2014
it sounds like your bolt is upside down try rotateing it 180 degrees
Tippmann 98... | Answered on Dec 24, 2013
Buy new ones.
Tippmann 98... | Answered on Sep 09, 2013
Time to lube (oil) the gun. A few drops of oil in the inlet hole (where you screw on your tank) should do and then dry fire the gun. If no luck you may need to tear down the gun and clean and lube the internals.
Here is your manual.
http://www.paintballadvisor.com/manuals/Tippmann%2098c%20manual.pdf
Tippmann 98... | Answered on Feb 22, 2013
One.. dirty...
Two.. no lube/wrong lube...
Three.. no air...
or any combination of the above. Make sure you have a full tank, clean the marker and use paintball-specific oil to lube the internals. The 98 is a very dependable marker and I'm sure once you have the basics down you'll find it very reliable.
8^)
it could be a combination of a number of things.. most likely it has to do with the type of paint you're shooting; in regards to shell.. tippman guns are harder on paint therefore require a harder shell paint, also not all paintballs are exactly .68 caliber, meaning some a bigger and some are smaller.. could be that they're slightly to big for the bore of you barrell
Tippmann 98 Custom Act Paintball Gun Logo
77 questions posted
Top Tippmann Sport & Outdoor - Others Experts
Andres Santana
Level 1 Expert
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Tippmann Sport & Outdoor - Others
Most Popular Question
when try cock gun valve makes
  • Sport & Outdoor - Others
