20 Most Recent Apple 3rd Generation 1GB iPod Shuffle Pink MB811llA Battery Questions & Answers
You can charge the iPod by connecting it to the Computer using the supplied USB cable.
Good Luck!!!!!!!!!!!!!
Apple 3rd... | Answered on Oct 19, 2009
iMessages can only go to people who have an Apple device. For others you have to use SMS (text message).
Apple Audio... | Answered on Dec 25, 2019
Hi Vicki Greenwood, so your Yamaha tells you, check that your speaker cables are not damaged or improperly connected
On the other hand, it controls the level of signal that is input from the Apple TV, it may be overmodulating
Take the tests and comment
Regards Franco Dosil
Hola Vicki Greenwood, por lo que te indica tu Yamaha, comprueba que los cables de tus bafles no esten da?ados o mal conectados
Por otro lado, controla el nivel de se?al que le ingresa desde el Apple TV, puede estar sobremodulando
Haz las pruebas y comenta
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/2/319822/01_om_htr-5940.pdf
Apple Audio... | Answered on Oct 06, 2019
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
Apple Audio... | Answered on Sep 16, 2019
I think you can try Leawo Blu-ray Ripper, it is an all-inclusive tool for handling both Blu-ray and DVD discs. The ability to decrypt Blu-ray disc with MKB level ranged from 0 - 21 and with AACS and BD+ protection has made it the strongest ever to rip Blu-ray videos.
Here is the full guide to tell you how to rip blu-ray or DVD to iPod video.
Apple Audio... | Answered on Aug 14, 2019
Unfortunately, lightning may have damaged your equipment beyond simple fixes. Most likely the sensitive circuits inside are blown, and you may need to replace them all.
Apple Audio... | Answered on May 24, 2019
MOV is a commonly used format.I think MOV/MP4 format is suitable for QuickTime,WMV means windows media video which is most preferred for windows apps.QuickTime apps provide by apple,some apple apps are not supported other OS apps format file.so i think MOV/MP4 format is a best for QuickTime. http://www.aimersoft.com/convert-mov/convert-quicktime-mov-to-mp4.html
Apple Audio... | Answered on May 22, 2019
MOV is a common multimedia format often used for saving movies and other video files; uses a proprietary compression algorithm developed by Apple Computer; compatible with both Macintosh and Windows platforms.
To play a MOV file, use this player
http://movplayer.net/
Apple Audio... | Answered on Apr 15, 2019
Press and hold the home button and the power button until you see the apple logo.
Of on a nano, the home button and play button
Google
Apple (model) soft reset
https://www.google.com/search?safe=off&ei=ON9xXNjvCcWfjwSqg7vQCQ&q=ipod+soft+reset
Apple Audio... | Answered on Feb 24, 2019
Did you try a different charger and charging cable? if you did, then probably the buck/boost converter connected to the battery is broken. This is an advanced repair to do, but you can try to look on ebay for a charging port for your ipod model.
Apple Audio... | Answered on Jan 15, 2019
Could you please add a picture of the components which are heating up crazily? There is a good chance these are voltage rectifying chips. Those will boost the voltage up or buck the voltage down to a specific number.
Please add the picture so I can take a look at which components they are.
Go to settings -> Time and language, disable automatic time sync and click then on "set time"
The only way to correctly download the OS is through the Apple App Store.
iOS 11 is now out of date. iOS 12 has been released.
Apple Audio... | Answered on Nov 17, 2018
Apple 3rd Generation 1GB iPod Shuffle Pink MB811llA  Battery Logo
3 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Audio Players & Recorders
Most Popular Question
charge ipod shuffle 3rd generation
  • Audio Players & Recorders
