20 Most Recent Lexicon Omega Desktop Recording Studio Questions & Answers
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Lexicon Omega... | Answered on Apr 16, 2011
One can burn up equipment if you have powered parts of it from different sources...such as connecting things together that get their power from different receptacles. Ground bounce and fault currents of defective equipment can burn up things. You will probably have to send your unit back to the factory for repair.
Lexicon Omega... | Answered on Jan 08, 2011
An insidious problem is if the throughput of your computer is being used up by things like anti-virus, anti spyware. Turn OFF ALL of these throughput hogs when doing audio operations. Also turn off wireless communication and ANY other active USB throughput hogs.
These hogs will usually cause sharp noises thaat are essentially discontinuities of the audio waveform.
IF the noise you are getting is a "hiss" type noise, that is different. That is USUALLY caused by the user failing to set the gains and levels properly. Some electronic noise is from the statistical background noise likited by the laws of physics, It is important to record and set the level well above these noise floor points.
Balancing gain is important. Set the amplitude of the line out to be near line level and lower the gain of following amplifiers. This is just good practice.
Anyway, decide which of these two noise sources might be what you are seeing.
The third noise MIGHT be from ground loop noise... for that power ALL, and I do mean all interconnected equipment from teh same power receptacle/source AND used balanced lines such as XLR or TRS wherever possible.
Lexicon Omega... | Answered on Dec 13, 2010
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Lexicon Omega... | Answered on Nov 13, 2009
you SHOULD be able to.
Just use Direct Sound in the host tab.
Lexicon Music | Answered on Mar 19, 2017
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Music | Answered on May 04, 2020
Yamaha pianos go through a self test on start up. This could indicate a problem on the main motherboard.
Try a hard reset.
Hold down top C key while turning on.
Wait for it to start up, if it still freezes its time to take it to the repair shop.
Music | Answered on Mar 14, 2020
Try this website:http://tubesandmore.com/ Look under reverb tanks. Check to see how many springs your old tank has and what size it is. I think Marshall used Accutronic tanks but have a look at all of them. There are pictures and info for each. Hope this helps.
Music | Answered on Mar 01, 2020
See https://www.diyaudio.com/forums/multi-way/99647-magnavox-horn-specs.html
Music | Answered on Feb 09, 2020
For what it's worth, the Style AA was advertised in 1910 catalogs. I believe they continue to have been made for forty or so years after that. So any time between 1909 (when pianos started being labelled 'Behr Bros') through to around 1950 or so ,,,
You can see the catalog https://antiquepianoshop.com/online-museum/behr-brothers/#berh2
Zager yes, but Salisbury Cathedral is a church in Hampshire UK
https://www.google.com/search?q=Is+Salisbury+Cathedral%2F+Zager+Guitars+legit
Music | Answered on Jan 16, 2020
Lexicon Omega Desktop Recording Studio Logo
Popular Tags
7 questions posted
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
View Most Popular
Lexicon Music
  • Lexicon Music
Most Popular Question
just got lexicon
  • Music
