20 Most Recent Allen & Heath Xone:92 DJ Mixer Questions & Answers
You've pressed the "solo" button by accident.
Allen & Heath... | Answered on Jun 04, 2014
If you pull the knobs off, you will find lock nuts under them. You could tighten them up. See if the knobs have set screws on them to lock them in place before pulling them off. On Allen & Heath, I don't think they do but, just in case.
Allen & Heath... | Answered on Mar 29, 2014
Have you tried contacting them here:http://www.allenorgan.com/www/company/service_support.html
Allen & Heath... | Answered on Nov 16, 2010
Sounds like it MIGHT be a power supply problem. Needs service!
Allen & Heath... | Answered on Aug 28, 2009
Usually this problem happens due to bulging of filter capacitors in the Power Supply Unit. identify and replace faulty capacitors with higher voltage ratings to fix this problem. Replacement of the capacitors is very easy if you have repair experience or at least soldering experience.
Allen & Heath... | Answered on Jan 27, 2019
cachepe.samedaymusic.com/.../gl2400ug_ap5597_2-42fad5e2de1bc79db38576be174464d4.pdf - United States
Above is your user manual below is a service and repair manual.
http://www.performanceaudio.com/cgi/product_view.cgi?products_id=16696
Indeed i would suspect something around your Final Output semiconductors, and any associated resistors?
You really must obtain a service manual, here there are the troubleshooting steps required to isolate and hopefully allow repair of your unit.
Look for any discolored components etc, check if any are overly hot... use a temperature probe on suspected components. Freeze spray may also be useful in diagnosis.
Use your eyes & nose to isolate the bad burnt overheated components, I sometimes use a straw up a nostril and selectively go over suspect parts, and "Sniff" to try and detect the overheated smell... it works.
http://www.allen-heath.co.uk/uk/TechnicalSupport.asp
Above is your tech support link, contact them for any info you require.
Allen & Heath... | Answered on Nov 30, 2010
Last post will not let me put pictures for some reason so mine says Ibanez 61-12491
Music | Answered on Jan 09, 2021
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Music | Answered on Dec 20, 2020
This is a common problem with Bugera. And, unfortunately they are made by Behringer who is known to have the worst customer service of all and do not follow through on their warranties.
Music | Answered on Dec 12, 2020
Request the manual from Rogue.
Music | Answered on Dec 07, 2020
It's here $16.15
TOP+ AC Adapter Charger for TC Electronic Vibraclone ...
www.amazon.com > TOP-Adapter-Charger-Electronic-...
Amazon.com: TOP+ AC Adapter Charger for TC Electronic Vibraclone Rotary Effects Pedal Power Supply Cord Mains PSU: Electronics.
Music | Answered on Dec 02, 2020
I suggest checking to make sure those 2 units can actually use the same adapter and also check the polarity on both to see if they are the same. Most stompbox stuff usually has negative on the center of the socket, instead of positive like other devices. If I spend a little time I could find the manuals and find out for myself but, this was my logical "top of my mind" kind of advice. Those values (volts,mA, and polarity) must be known in order to help you further. I believe it will be 9v, a few 100 mA's, and negative in the center on both but, not sure.
Music | Answered on Nov 25, 2020
Allen & Heath Xone:92 DJ Mixer Logo
7 questions posted
Top Allen & Heath Music Experts
Marvin
Marvin
ray gallant
Watching Him
Watching Him
Are you an Allen & Heath Music Expert? Answer questions, earn points and help others
View Most Popular
Allen & Heath Music
  • Allen & Heath Music
Most Popular Question
mic section lights filter section quit
  • Music
