20 Most Recent DIGITECH VOCALIST LIVE 2 Questions & Answers
2answers
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
11/3/2021 3:15:30 AM • DIGITECH... • Answered on Nov 03, 2021
Factory reset
to reset hold down both foot switches and power up ity worked for me.
1/5/2019 5:18:56 AM • DIGITECH... • Answered on Jan 05, 2019
NO power light from Digitech Vocalist 2 live.
Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more.
3/15/2016 7:31:07 AM • DIGITECH... • Answered on Mar 15, 2016
Can i use this without the guitar,, lead vox only ?
Only for the effects. In order for the harmony functions to work it has to have a reference point.
4/24/2015 1:09:58 PM • DIGITECH... • Answered on Apr 24, 2015
The vocal cuts out completely from time to time. Comes back after a while but keeps cutting out at intervals. Have two of these and both do it. Is it my set up, is it overload in some way. Guitar ok.
The amp or pre-amp for the vocals built into the unit is failing when it gets warm. This is a common problem with electronics, that when it cools down cures itself until it warms up again a few seconds later. The units need repair or replacement.
12/22/2013 9:30:13 AM • DIGITECH... • Answered on Dec 22, 2013
2answers
No vocal sound
It sounds like the guitar level input to the unit is too low.
NOTE: With this product you MUST use an amplified or electric guitar that has a preamp within it.
If you have a straight guitar that does not have an amp in it, buy a preamp to first run the guitar through.
3/6/2013 2:34:03 PM • DIGITECH... • Answered on Mar 06, 2013
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.- thegorisb
11/3/2012 11:08:08 AM • DIGITECH... • Answered on Nov 03, 2012
My harmonizer powers up but does nothing else, and there's no display.
I hope that I'm wrong but my Boss GT-6 pedal went south on a firmware update and is now a door-stop. Good luck.
11/1/2012 5:21:34 PM • DIGITECH... • Answered on Nov 01, 2012
All leds on vocalist live 2 areon nothing happens
depending if needs to be connected to something? need more detail.
8/12/2012 7:47:16 PM • DIGITECH... • Answered on Aug 12, 2012
The digitech vocalist live 2 ,the left side button(reverb,enhancer) , activates the right side (harmony) LED's on the circuit board itself are lit up and nothing happens. t
The buttons are probably scanned as a matrix and possibly a circuit board has been cracked causing wrong data to go to the microprocessor in it. It is unlikely this will be a DIY fix so you should contact Digitech for a repair facility.
6/22/2012 8:56:46 PM • DIGITECH... • Answered on Jun 22, 2012
2answers
I was using my digitech vocalist live 2 pedal
Yeah I have an idea... It is likely static electric discharge. At this time of the year we get zapped touching metal things and it also drives electronics nuts... You don't even have to feel it to get zapped.
Try using in your bare feet and see if it fusses... We had a lady vocalist wearing those ugg boots and caused static pops in her microphone... anyway try the test and if it fixes the problem, then look up Staticide spray... You can get it at Amazon.com for example... spray floor in the area you are playing on to kill the static.
The only other thing is to check if wiggling the power input plug causes the problem. Those plugs are notorious for poor connections when they wear.
9/15/2011 8:30:10 AM • DIGITECH... • Answered on Sep 15, 2011
Distortion on vocal reproduction on
You need to check the actual signal levels to make sure they are within the specs for the unit. The mic input is low impedance. Your mic should be like a Shure SM58 or equivalent. The output is fairly high... up to +14DB which will require you to turn down the trims on a mixer this runs into or set a -20Db pad at the input. I suspect your distortion is from the device output to the mixer input. It is VERY important that the mic does NOT "hear" the speakers as the feedback loop resulting will be mass distortion. The guitar should also not "hear" the mains.
5/7/2011 4:48:38 PM • DIGITECH... • Answered on May 07, 2011
Vocalist live 2 problem. power
NO power light or audio from Digitech Vocalist 2 live. Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more. A DC adapter MAY light up the unit but not make it pass audio. Lights can be lit but that is NOT an indication thaat correct power is applied. They likely use the AC input to generate both positive and negative voltage within the unit. The use of a DC adapter will prevent generating one of these required voltages and prevent audio from passing.
1/14/2011 5:21:20 AM • DIGITECH... • Answered on Jan 14, 2011
The screen is very very dim
Make sure you have the correct power adapter. It should be 9VAC at 1.3Amp (1300ma).
1/10/2011 4:49:48 AM • DIGITECH... • Answered on Jan 10, 2011
2answers
After playing for about half
How long is it before you can play again? Does it cool off and then start working again?
11/10/2010 7:28:51 AM • DIGITECH... • Answered on Nov 10, 2010
Power supply for vocalist 2 goes bad twice
Likely the supply was underated OR it is getting hit with a transient. Transients are common in some venue power systems.
There should be a label on the unit as to what the power requirements are. Make sure the power adapter is rated for that or more CURRENT in amps or milli-amps.
Are you sure the power supply has failed? There could be an intermittent in the unit, most likely with the inout power jack... They often get damaged by tripping over the power cord.
2/9/2010 9:21:10 PM • DIGITECH... • Answered on Feb 09, 2010
I use the digitech vocalist and half the time I
Make sure the sound is on.
12/20/2009 3:33:00 AM • DIGITECH... • Answered on Dec 20, 2009
DIGITECH VOCALIST LIVE 2 Logo
33 questions posted
Top DIGITECH Music Experts
NOEL
NOEL
Kardoc
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
View Most Popular
DIGITECH Music
  • DIGITECH Music
Most Popular Question
  • Music
