20 Most Recent
Gibson SG Standard Electric Guitar with Case Questions & Answers
I have a gibson SG guitar which sometimes loses
I would be looking at batteries in your wireless getting old or something overheating.
The batteries will drop the power a bit and that can kill the range sound not distance so it acts like it is clipping or isn't being amplified so you loose the peaks and the result is dull sounds. You can also get this if it is overheating.
There could be something else but batteries will recover and seem fine. To check this out I would try either fresh batteries or a battery pack. If you can make sure they are putting out the right volts with a meter that would help. If you have to you could leave it on for a while and let it run the battery down a bit and see if it starts sounding dull. It might take a while as you won;t be pulling as much power as when playing but it will tell you if it is power related which means batteries.
5/24/2010 11:19:03 PM •
Gibson SG...
Answered
on May 24, 2010
What year was a Gibson RB 250 s/n 83447516 made
Probably in 1983
https://www.gibson.com/Support/Serial-Number-Search
but, call to confirm because guess what it says?
Gibson Banjos 1988 to present
Earl Scruggs Models
Standard:
Sequential production number, starting at 001
'49 Classic:
YY-RR
YY = Year of manufacture
RR = ranking number (starts at 01)
Golden Deluxe:
YY-RR
Flint Hill Special:
FH-YY-RR
Special:
ES-YY-RR
Style 250
250-TT-RR
Granada
YY-MM-RR
YY = Year
MM = Month
RB
RB### = sequential production number
All other models
S(S)-YYMM-RR
S(S) = style (excluding style 250 - see above)
YY = Year
MM = Month
RR = ranking number
11/8/2019 1:45:43 PM •
Gibson Music
Answered
on Nov 08, 2019
I have a solid body Gibson guitar serial number 906279. What year was it made? Any other info?
That number matches a guitar made at the
Kalamazoo Plant, MI, USA in 1959.
The serial number does not give us the exact model, but a genuine Gibson solidbody made in 59 is likely to be a Les Paul Junior or a Melodymaker. Reverb prices those around US$7000 depending on condition and finish.
If it is not a fake (there are plenty of those around) and it does look that old, you could decide to get an online professional valuation from
https://guitars.com/appraisals.
If you do, take especially good photos of both sides of the headstock and any other Gibson logos on it.
12/23/2017 3:58:06 AM •
Gibson Music
Answered
on Dec 23, 2017
Hi out there, I am trying find the correct age of my Classic Gibson Les Paul and am struggling. it's serial number is 064336. Any help would be great fully appreciated. Thank you
This is actually not an easy question to answer a Gibson (as you may already know) has used multiple numbering schemes..Your guitar may be a 2000... This is from Gibson's site: "Les Paul Classic: This model features an ink stamped serial number with no "MADE IN USA" (just as we used on the original 1952-1960 Les Pauls). Most will be 5 to 6 digits in length, but the earliest examples feature 4 digit serial numbers. There should be a space after the 1st digit with the 4 and 5 digit serial numbers, and no space with the 6 digit numbers. The 1st digit indicates the year of manufacture for the 4 & 5 digit serial numbers, these were used from 1989-1999. The 1st and 2nd indicate the year of manufacture for the 6 digit serial numbers which we've been using since 2000. Examples - 9 xyx = 1989 (4 digit number beginning with "9" used only in 1989) 0 xxyx = 1990 9 xyxx = 1999 00xyxx = 2000 05xyxx = 2005" http://www.gibson.com/Support/Serial-Number-Search.aspx/ Alternatively many people have gotten the best answer by calling Gibson directly: USA: 1-800-4GIBSON HTH!
12/11/2017 11:12:29 PM •
Gibson Music
Answered
on Dec 11, 2017
