20 Most Recent
Gold Medal Products Gold Medal 3008SS Deluxe Whirlwind Cotton Candy Machine w/ Lotta Volts System Questions & Answers
Cotton candy maker will not power on
If you have checked to make sure it is plugged in, and outlet has power. The next thing to check is a circuit breaker in the front underneath the handle. A small white button to push.If resetting the breaker, and it runs for a second then trips again, do not reset it again, this indicates a ground fault in the machine and it needs to be repaired by technician.If the breaker doesn't change the operation (no power) then it should be repaired by a technician as there is no easy fix for the symptoms you have described.
Maplin N20FR - damp test meter. I have no
N20FR - Used to measure the moisture level in sawn timber (also cardboard, paper) 6 to 44% on the left hand scale and hardened materials (plaster, concrete and mortar) 0.2 to 2.0% on the right hand scale
4/14/2024 9:12:34 PM •
Kitchen...
Answered
on Apr 14, 2024
Paragon spin magic 5qr, when spinning causes bowl to shift.
Athletes often talk about the need to find "the zone." This is a state where everything seems to come together and they are able to achieve feats they never thought possible. For bowlers, this zone is often referred to as "the spin zone." When bowlers are able to get their bowling ball to rotate quickly on the lane, they can cause the ball to move in unexpected ways.
2/8/2024 2:23:46 PM •
Kitchen...
Answered
on Feb 08, 2024
Gett motor out of toledo meat slicer
Removing the motor from a Toledo meat slicer involves several steps. First, unplug the slicer to ensure safety. Locate the motor, typically positioned near the base. Depending on the model, you may need to remove a cover or access panel to reveal the motor. Disconnect any electrical connections, such as wires or cables, linked to the motor. Next, loosen and remove any securing bolts or screws holding the motor in place. Carefully lift the motor out of its housing, ensuring that no other components are obstructing its removal. Exercise caution and refer to the specific user manual for your Toledo meat slicer model for precise instructions.
2/3/2024 5:14:04 AM •
Kitchen...
Answered
on Feb 03, 2024
