20 Most Recent MARCY ME 709 Recumbent Exercise Bike Questions & Answers
Refer page 7 in this manual for making sure the wires are routed correctly. Please drop a line to confirm if this helped. http://www.hayneedle.com/images/PDF/IPX007.pdf
MARCY ME 709... | Answered on Aug 21, 2014
It may be best to download the instruction from this website.
MIGHT NEED OILED IN A FEW PLACES . NOT KNOWING WHAT MAKE YOU HAVE DOES NOT HELP YOU WITH HELPING US FIGURE IT OUT EITHER
Cycling | Answered on Jul 22, 2020
If you shop around there are plenty of styles of handlebar. Might be worth you trying a bar from a dirt bike or some sort of cruiser bike.
Another option could be to tilt your existing bars back a small amount and add a fork stem riser. Sometimes simply raising the handlebar height on the fork top can help.
Cycling | Answered on Jul 16, 2020
I do not think this will help, but it might give you some ideas:
http://www.protecboardracks.com/products.aspx
Another design, that you would have to modify for your purpose but a very good idea:
http://www.woodcentral.com/articles/shop/articles_794.shtml
again use this principle and do your own drawings:
http://www.woodstore.net/lumstorrac.html
Cycling | Answered on Jun 27, 2020
I can't find a manual, but the install is pretty basic. You need to bolt it to the frame, then remove one of the sprockets on the derailleur to get the chain through, then replace. Attach the cable through the locking nut, using the lowest gear first, then run it to the highest gear to make sure it runs through them all. There are some set screws to set so that the derailleur doesn't go past the upper/lower gears. It's all a matter of adjustment from there.
Hope this is of help
Joe
Cycling | Answered on Jun 06, 2020
Here is the link for front derail...
https://www.amazon.com/SHIMANO-XT-FD-M786-Down-Swing-Derailleur/dp/B007HDMY2U/ref=sr_1_1?dchild=1&keywords=shimano+xt+front+derailleur&qid=1591136571&sr=8-1
Cycling | Answered on Jun 02, 2020
try manufacturer or online search
Cycling | Answered on Apr 23, 2020
Here are some things the book doesn't tell you:
You have to completely reset the speedometer and lose your odometer to reset the MPH. Hold both buttons for 3 secs to get reset. (Remember to use the left button to walk through the setup process and use the right button to change the settings.) First set the wheel size using Ideluna's settings above on this page (right button to change the setting and left button to go to next number). Next is MPH/KPH, after wheel size setting, push left button again and km flashes. Push right button to change the setting to MI. Next is TIME. Push left button and you'll see the time. Hold down left button till 24hr appears. Push right button to change to 12hr. Then push left button to go to flashing hour. Change with right button. Then left button to go to flashing minute. Right button to change minute, hold down to change minutes fast. Now you are set up. Now the process changes, use the right button to walk through the menu and use the left button to reset. Don't push both buttons anymore unless you want to reset everything again. If you want to reset something just hold the left button down until 0. When you are in SCAN mode, push the right button to go to Time, To go back to SCAN once, hold the right button down - It will scan everything once and return to TIME. To go to ODO, push right button once, push again for DST, push again for MXS, push again for AVS, push again for TM, push again for SCAN to stay in SCAN.
Cycling | Answered on Apr 03, 2020
TO TH REPAIR FORUM ABSOLUTELY NOTHING .
Cycling | Answered on Mar 13, 2020
you have to put the pad in it's 1st possiton then tighten the screws.
Cycling | Answered on Feb 19, 2020
if the batter is goo , throw it away , junk got wet
Cycling | Answered on Jan 26, 2020
MARCY ME 709 Recumbent Exercise Bike Logo
5 questions posted
Top MARCY Cycling Experts
Marvin
Marvin
John Egan
John Egan
Andrew Taylor
Andrew Taylor
Are you a MARCY Cycling Expert? Answer questions, earn points and help others
View Most Popular
MARCY Cycling
  • MARCY Cycling
Most Popular Question
putting bike together
  • Cycling
