20 Most Recent Garmin NUVI 255 PERSONAL GPS Device Questions & Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Garmin NUVI 255... | Answered on Aug 15, 2010
Tip
Download Nuvi 255 Manual
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin NUVI 255 PERSONAL GPS Device
Are you sure you have set the mark correctly. 30 ft would be acceptable due to regulations , but 2 miles is quit a lot of variance. Check to be sure your map is up to date as some maps were never updated with road changes if you are going off a pre-set map load
Garmin NUVI 255... | Answered on Mar 09, 2010
When you first tun them on it is supposed to tell you to touch all four corners in a row.....this calibrates it. Yours may be differenr but the most of them are this way.......
Garmin NUVI 255... | Answered on Dec 25, 2009
If you are pressing the on switch and it is not switching on then try plugging this in someone else's care and see if it works. If it doesn't then there is an issue with the unit or the charging cord. Try a different cord and if that doesn't fix it then it is the unit. Good luck.
Garmin NUVI 255... | Answered on Jul 16, 2009
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Garmin NUVI 255... | Answered on May 22, 2009
You charge the unit via your cigarette lighter socket using the charge lead supplied. Generally you type a zip code if you know it and the satnav will calculate your route.\if you dont know the zip code type in an address but this gives several areas. Zip codes are preffered.It will talk once you start driving giving you forwarning of any turns you need to make in advance. Good Luck
Garmin NUVI 255... | Answered on Mar 17, 2009
Download from the Garmin site and follow the onscreen instructions.
Garmin GPS | Answered 3 days ago
Hello
Download the Garmin Express application
The Garmin Express application is used to update maps and device software on compatible GPS devices.
Install the application on the computer
Connect a compatible Garmin device
Navigate the on-screen prompts
The Garmin Express application will update the maps and / or software on the device.
Garmin GPS | Answered on Jul 28, 2020
PDF]Garmin Drive™ 40/50/60 - CNET Content Solutions cdn.cnetcontent.com/3e/d4/3ed4aeb7-d7f3-4ded-ab78-4c0cfb4525b1.pdf ... and to make changes in the content of this manual without obligation to notify any person or organization of such ... Garmin Drive 60 Device Overview.
Garmin Drive™ 60LM ' Garmin
https://buy.garmin.com/en-CA/CA/p/523227
  1. Cached
Garmin Drive is a 6-inch GPS navigator preloaded with lifetime maps of the U.S. or U.S. and Canada, plus new driver alerts to encourage safer driving. Find out ...
Garmin Drive™ 60LMT ' Garmin
https://buy.garmin.com/en-CA/CA/p/523327
  1. Cached
[PDF]Garmin DriveSmart™ 50/60/70
static.garmin.com/pumac/DriveSmart_50-60-70_OM_EN.pdf Owner's Manual ... Garmin DriveSmart 60 Device Overview. ... Driver Awareness Features and Alerts........................ 3. Enabling or Disabling Audible Driver Alerts.
Garmin Drive 60 Manuals
https://www.manualslib.com > Brands > Garmin Manuals > GPS
  1. Cached
Garmin Drive 60 Pdf User Manuals. View online or download Garmin Drive 60 Owner's Manual. manual for Garmin Drive 60 Google Search
Garmin GPS | Answered on Jul 16, 2020
Go to the garmin web site and follow the on screen instructions.
Garmin GPS | Answered on Jul 03, 2020
Go to settings and set the correct time to your location!
Garmin GPS | Answered on Jun 11, 2020
Has yours been updated recently? I updated mine, (about a year ago), on the website and it wiped all the map data.
I think some of the more recent software update versions have caused problems for certain sat nav models.
Try logging onto the Garmin website, connect you sat nav to you computer and check it has the current software updates. Older models sometimes need to be reset to an previous version of the software to work correctly. To do this you might have to contact Garmin directly by Email to get them to send you the correct software version.
Hope this helps.
Garmin GPS | Answered on Jun 08, 2020
notify garmin for assistance
Garmin GPS | Answered on Apr 02, 2020
Hi Earl,
Sometime it could just be of aging. I have a 130, it was having similar problems, until i realized it was the screen not showing, but power on turning on. In your case, I probably probably try a hard factory reset as follows:
To perform a master reset:
  1. Turn off the device.
  2. Press the PAGE, ENTER2, and POWER buttons simultaneously.
  3. Release all buttons once the Do you really want to erase all user data? message appears.
  4. Select Yes.
hope this helps!
Kevin
Garmin GPS | Answered on Mar 29, 2020
Garmin NUVI 255 PERSONAL GPS Device Logo
Popular Tags
12 questions posted
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
Garmin GPS
  • Garmin GPS
Most Popular Question
says low battery charge
  • GPS
