20 Most Recent
Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Questions & Answers
How do i top up the lubricating oil in the hydraulics of a mercury outboard engine
I suppose you mean the oil in the Trim system...
Lift the engine all the way up,
Place the jackstand to keep the engine fully up.
You'll see a plastic plug in the center cylinder.
Unscrew that plug. ( There can be some pressure, take care of your eyes!)
Fill with ATF-oil till the level is at the bottom of the plug hole.
Screw the plug back in.
Lower the engine.
Done!
10/4/2016 5:17:57 PM •
Clymer...
Answered
on Oct 04, 2016
Frequent ignition problem on yamaha 28 A 1987 models
known as maintenance !! they dont clean them selves and more you use them more times you need to check and clean them ! unless they have shorts or damaged wires etc these engines are simple and reliable ! if your getting lots of dirt under the flywheels then check the top crank seals not leaking as this will foul the contacts also !
6/25/2015 8:43:23 PM •
Clymer...
Answered
on Jun 25, 2015
Engine diagram parts
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
1/28/2015 9:55:14 AM •
Clymer...
Answered
on Jan 28, 2015
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Yamaha 25 nmo
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I just bought a new boat and need to buy a boat
Never buy a trailer with the same capacity as the weight of your boat! This can be very dangerous! Instead, make sure the trailer's capacity is at least twice that of the weight of the boat, all your gear, and the boat's motor.
12/5/2023 6:58:35 AM •
Boating
Answered
on Dec 05, 2023
What is the size of a small yacht?
Small yachts, also known as Silboats or Cabin
Cruisers are 20-40 feet. There are of course larger Yachts that can get to over
100 feet, also known as Mega Yachts.
11/15/2023 8:08:55 AM •
Boating
Answered
on Nov 15, 2023
