20 Most Recent RTO Accugreen 1000 Drop Spreader Questions & Answers
Depends on how acidic your lawn is have you taken some samples to your farm and garden center to have it checked A local coop could also send in samples for you that way you will have accurate idea of how much you need.
RTO Accugreen... | Answered on Apr 14, 2012
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
RTO Accugreen... | Answered on Jun 15, 2011
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
RTO Accugreen... | Answered on Aug 09, 2009
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
RTO Garden | Answered on Nov 22, 2013
Make sure your shut off valve is on positon not part way off,check for a screen plugged up in fuel tank or inline fuel filter, check for bad spark plug engine oil top up maybe saftety sensor when oil is low if you remove the fuel line from carb does gas flow straight out no problem?
Joe
RTO Garden | Answered on Oct 10, 2012
RTO Accugreen 1000 Drop Spreader Logo
11 questions posted
Top RTO Garden Experts
Dennis Key
Dennis Key
Bill Boyd
Tom Chichester
Are you a RTO Garden Expert? Answer questions, earn points and help others
View Most Popular
RTO Garden
  • RTO Garden
Most Popular Question
accugreen 1000 wire settings
  • Garden
