20 Most Recent
Ryobi ZRRY46501 Factory-Reconditioned 12 Amp 3.42 HP Electric Tiller Cultiv Questions & Answers
Can't get the cover off
Remove the first screw, peel back the 12 amp sticker, remove the second screw, use a screwdriver to pry the top and both sides of the cover. The cover should now be free, then remove the grommet that holds the power and throttle cable to the cover to completely remove it.
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Ryobi bp42 backpack blower won't stay running and spit out gas
Common issues and possible solutions:
Fuel-Related Issues:
Check the Fuel Level: Ensure that the blower has enough fuel in the tank. If it's running low, refill it with fresh, properly mixed fuel as specified in the user manual. Remember to use the correct fuel-to-oil ratio to avoid engine damage.
Inspect Fuel Lines: Examine the fuel lines for any clogs, kinks, or leaks. Clean or replace them if necessary.
Clean the Carburetor: A dirty or clogged carburetor can cause starting and running problems. Remove the carburetor, clean it thoroughly, and check for any damaged components. Replace the diaphragm and gasket if needed.
Spark Plug Issues:
Check the Spark Plug: Inspect the spark plug for signs of wear, fouling, or damage. Ensure it's properly gapped and functioning. If needed, replace the spark plug
Air Filter and Intake System:
Clean the Air Filter: A clogged air filter can affect performance. Remove the air filter, clean it, and ensure proper airflow.
Inspect the Intake System: Make sure the intake manifold is secure and not loose. Tighten any screws or connections.
Heat Soak:
Sometimes, backpack blowers experience heat soak, where the engine becomes too hot to start. Allow the blower to cool down before attempting to restart it.
Compression and Ignition Coil:
Compression Test: Check the engine's compression using a compression tester. Low compression may indicate internal engine issues
Test the Ignition Coil: Ensure the ignition coil is functioning correctly. A faulty coil can lead to starting problems.
