20 Most Recent AMD Athlon64 2800+, 1.8 GHz Athlon 64 (amdada2800axbox) Processor Questions & Answers
Download driver free
CPUs do not have drivers. They do not contain LAN, Audio, or Video components. These are part of the motherboard they are installed upon. You need to provide the motherboard manufacturer, model number, and revision number, along with the specific Operating System you are running. We can then help you find the driver(s) you need.
1/6/2016 10:10:32 AM • AMD Athlon64... • Answered on Jan 06, 2016
I have AMD Athlon(tm) 2800
There is a full list of AMD 64 processors at http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors.
The Socket of your CPU is 754 which means that the highest you can go is to a 3400+ at 2.4GHz.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Thanks.
4/23/2014 12:59:17 PM • AMD Athlon64... • Answered on Apr 23, 2014
Have amd athlon 2800, 1.8ghz,
YOU CAN PUT THE MAX OF 2GB. AS OF NOW YOUR ARE HAVE 512MB. PLEASE PURCHASE THE RAM BASED ON YOUR MOTHERBOARD
4/23/2014 12:56:22 PM • AMD Athlon64... • Answered on Apr 23, 2014
Motherboard drivers
The issue of motherboard drivers is not affected so much by the processor itself as the chipset type/version installed on the motherboard and the operating system you plan to run on it. If you can provide the motherboard manufacturer, its model number and revision, and what operating system you are going to run, we can point you to the correct motherboard drivers.
11/29/2013 12:21:28 AM • AMD Athlon64... • Answered on Nov 29, 2013
How do i know if there is a defective mother board
check bios display if found massage from bios reset bios to default and start again bios reset using given methos1 short battery terminal when battery out2 option from bios massage on diasplay
5/16/2012 6:54:26 AM • AMD Athlon64... • Answered on May 16, 2012
I have amd athlon 64
A suitable graphics card will help your computer system display better graphics. You will need a graphics card and maybe you could do with at least 1GB of RAM.Take care!damnor01
10/8/2011 8:25:10 PM • AMD Athlon64... • Answered on Oct 08, 2011
I have a Asus P4GE-MX motherboard with processor
You will not find a better processor or replacement parts, this system is too old and parts are not being made. Newer systems are 4 generations better and prices are heading down, buy a new system with Intel CORE or CORE2 chips or the latest I3, I5 or I7 chip using DDR3 memory. DDR4 will be arriving in 2012, prices on old DDR3 will continue to go down.
9/23/2011 9:05:32 PM • AMD Athlon64... • Answered on Sep 23, 2011
Sir , i found my
Processors do not fail unless they are mishandled or installed incorrectly. This system is very old and uses memory that is no longer available. Try starting your system with no memory, does it start to beep repeatedly? The memory may be at fault. No beep, could be the motherboard has failed.You will not find replacement parts, you will need a new system.
9/23/2011 9:00:59 PM • AMD Athlon64... • Answered on Sep 23, 2011
Hi everyone I have AMD
Any motherboard, off-the-shelf, with a socket AM2 or AM2+ should work fine. None are being made, you will have to find old stock or used. New boards support AM3 and AM3+ using DDR3 memory now. The normat temperature range should stay below 60 degrees Celcius.
Cool & quiet: The motherboard bios controlls cooling. Turn it off and Windows can take over.
If you really want it, there is an extra software utility you can download from AMD to interact with the process, however it is not needed.
9/12/2011 9:33:08 PM • AMD Athlon64... • Answered on Sep 12, 2011
4answers
I have Installed Windows7 on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
6/23/2011 7:52:34 AM • AMD Athlon64... • Answered on Jun 23, 2011
Only ph.gameclub.com not accessible but my
try to search it in google.com
6/10/2011 2:09:30 PM • AMD Athlon64... • Answered on Jun 10, 2011
I havae VIAK8M Motherboard model
pLEASE DOWNLOAD THE DRIVERS FROM www.driverscollection.com
5/25/2011 9:58:48 AM • AMD Athlon64... • Answered on May 25, 2011
3answers
I am repairing a computer for a friend. When I
depending on the number of beeps and their durations you can search your motherboards bios beep codes which should tell you the general area of the fail
try unplugging and re-seating memory cpu videocard / monitor
these are the usual main culprits
5/6/2011 5:52:34 PM • AMD Athlon64... • Answered on May 06, 2011
After recovery has run and have restarted
Press f8 to go to boot order and set it up there
2/24/2011 11:27:15 PM • AMD Athlon64... • Answered on Feb 24, 2011
Monitor not display when i turn on machine
Hello there,
Is the monitor gives you are red or green led light? Make sure the cables are connected to the computer. Try to turn on the computer with the monitor. Then get yourself a flashlight and look closely to the monitor screen and see if you can view the desktop or icons on it. If yes, then your monitor's backlight have failed and needs replacement.
Please let me know how this goes. Thank you for using FixYa
2/23/2011 4:38:49 AM • AMD Athlon64... • Answered on Feb 23, 2011
No desplay and no boot
check the power unit, it may be faulty, bowwow one and test
2/14/2011 2:39:49 AM • AMD Athlon64... • Answered on Feb 14, 2011
2answers
Hi, I have the configuration processor :
Any socket 754 motherboard of your choice.
1/17/2011 2:00:17 PM • AMD Athlon64... • Answered on Jan 17, 2011
I want the sound driver for AMD Athlon 2800+
what brand of computer is it find out and go to their website and u can get it the info u provided is not the manufacture of ur computer its the processor type that is in it
1/12/2011 9:00:05 AM • AMD Athlon64... • Answered on Jan 12, 2011
Amd athlon 2800+ drivers
Click here to download the drivers for your Processor.
Select Processor for option 1
Select AMD Athlon 64 bit family for option 2
Now click view results.
It will then show a list of the available drivers for your processor.
Select whichever is appropriate.
You would need the AMD Processor driver version 1.3.2.0053
damnor01
1/4/2011 8:30:28 AM • AMD Athlon64... • Answered on Jan 04, 2011
AMD Athlon64 2800+, 1.8 GHz Athlon 64 (amdada2800axbox) Processor Logo
Popular Tags
30 questions posted
Top AMD Computers & Internet Experts
ExpressFiX
ExpressFiX
NOEL
NOEL
john h
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AMD Computers & Internet
Most Popular Question
everyone amd
  • Computers & Internet
