20 Most Recent Aquascape Designs Nursery Pro Ultra Pump Questions & Answers
Check the impeller shaft for cracks and rough patches. harlok_6.jpg If the impeller shaft is still smooth and in one piece the main motor bearing is damaged or worn out. A main bearing is not replaceable as accessing it would compromise the motor housing.
Aquascape... | Answered on Apr 20, 2011
It can be serviced. Most likely the impeller is jammed with debris.
Aquascape... | Answered on Nov 10, 2009
Remove the six (6) cushions underneath the base of the unit, revealing the screws.
Remove the six (6) screws with a Phillips head screwdriver.
Slowly separate panel from base, revealing the bulb, motor, etc..
Using a 4mm socket (you do not need a ratchet for the 4mm socket because it is hand-tightened in place), remove the nut and washers securing the "rainbow" disc on the vertical axle.
The bulb is held in place with a round retainer ring secured by two (2) springs.
Remove one (1) spring, not both, from the retaining ring and remove the retaining ring off the top of the bulb.
Remove the bulb and replace it with the same style / type which is a 10W 12V MR11 GU4 halogen bulb.
Reassembly is the opposite. When reassembling the "rainbow" disc on the axle, do it in the order: washer, disc, washer then nut.
Be sure not to over tighten the nut, just lightly hand tighten it.
You're all done.
Aquascape... | Answered on May 14, 2019
whatever the manual tells you
Garden | Answered 6 hours ago
That is usually caused by hangups in the pull starter system creating too much friction and not transferring the pull to the motor. Here is the parts diagram and exploded view
https://www.diyspareparts.com/parts/stihl/diagrams/br-380/
Garden | Answered 8 hours ago
A single pole push button would tie the fused battery feed at the ignition switch B terminal (red/white wire) to the ignition switch S terminal (orange wire).
This provides the same function as turning ignition switch to the start position with all safeties remaining functional. For engine run the ignition switch must be in run position. Push and hold push button until engine run. Turn ignition switch to off position to kill engine.
See link below for wiring diagram located in parts section of manual.
https://www.manualslib.com/products/Troy-Bilt-Ltx-1842-2923621.html
Garden | Answered 23 hours ago
WELL I GUESS YOU NEED TO REMEMBER WHERE YOU BOUGHTIT AND CONTACT THEM SEEMS WE MIGHT NEED TO KNOW A MAKE BUT ALASS YOU FORGOT THAT TOO
Garden | Answered Yesterday
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Garden | Answered 3 days ago
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Garden | Answered on Sep 24, 2020
i wouldnt even consider it. a truck mounted plow makes more sense
Garden | Answered on Sep 22, 2020
check your local home store. they sell things like this
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Garden | Answered on Sep 21, 2020
Make sure that the nozzle is clean. Also the tube between the nozzle and tank. Check inside the tank to be sure there is not any debris in the tank. Is the pump working and building up pressure? Does the cap O ring make a good seal?
This is how to solve the stiff Makita plunge saw easily!!!
I've just carried out the following steps and it's like a new saw.
Clear a table top and grab the following tools:
Philips screw driver
4mm allen key
grease- i used silicone grease
1. Take the base off the saw by removing the 4 x obvious screws.
2. If you look at the saw, you'll see that is pivots on a single pin at the rear. You'll also notice that there is a 4mm allen screw driven into that pin.
3. Remove the 4mm allen screw.
4. Fill the screw hole with grease and drive the 4mm allen screw back in (it'll force grease along the pin internally). Do this 3 or 4 times.
5. Work the mechanism back and forth as if you're plunging the saw- you'll notice that it becomes so much more easy to move.
6. Wipe away the black dirty grease that you have forced out of the pin. Reinsert the 4mm allen screw and tighten
7. refix the base and spring.
8. Job done.
This actually bugged me for ages until i finally decided to have a look and see what the issue was.
Garden | Answered on Sep 20, 2020
Retractable things - hoses and cables and even the mower recoil starter rope are invariably powered by a clockspring.
One end is anchored to the stationary casing and usually the centre is anchored to the rotating part. The spring is pretensioned by an amount sufficient to retract the hose, rope or cable all the way and then pulling out the rope, etc. will further tension the spring. The spring end is usually the part that breaks or the anchor.
The spring should be treated with respect as it is usually a great deal longer than expected and should you dismantle a troublesome unit it is very important to keep a firm hold on it because if they are allowed to unravel it is violent and there is a couple of sharp ends...
When a retractable unit ages it often becomes sluggish and it usually helps to wash and dry the spring and lubricate with a few drops of light machine oil or some graphite dust.
Garden | Answered on Sep 19, 2020
Aquascape Designs Nursery Pro Ultra Pump  Logo
Popular Tags
3 questions posted
Top Aquascape Designs Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you an Aquascape Designs Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Aquascape Designs Garden
Most Popular Question
pump making grinding
  • Garden
