20 Most Recent Pondmaster UV Clarifer Questions & Answers
According to Pondmaster, location doesn't matter as much as the flow going through it. You will have to plumb it where it is convenient for you, and allow for bypass valves. From their website:
How much water should I flow over my UV?
Just enough and not too much. Easy, right? On the contrary, this is a very tough question. To clarify, or control green water, the recommended dosage is 15 microwatts per second per cubic centimeter of water at a frequency of UVC of 265 nanometers. Whew! What this boils down to is a formula for the right amount of sunburn. You don't want to incinerate the cells, that would take too much energy, you don't even need to kill them, just to stop them from reproducing, so there is a maximum recommended flow rate that ensures that the cells passing through the light will get enough of a 'tan' to make them sterile (hence the term UV Sterilizer). Too fast a flow means not enough exposure and hence, no effect on the cells. Our UV's are rated, therefore, by the maximum flow that will still provide for enough exposure to the light to be effective. It follows that you can make a light more effective by slowing the flow, thus increasing exposure time, so we often recommend a Valved Bypass [insert link to Valved Bypass instructions] to selectively flow only part of the water going to the falls through the UV, to maximize exposure rates. However, and this is the tricky part, if the flow is too slow and not enough pondwater is being exposed quickly enough, the algae can reproduce before they make it into the UV. This sometimes happens in larger ponds with lots of nutrients and sunlight, and generally requires multiple UV units for effective control. The point is, do not exceed the maximum flow rates recommended or your UV just won't work, and decreasing the flow will typically make the UV work better.
Pondmaster UV... | Answered on Aug 31, 2011
harlok_7.jpgHope you find this helpful.
Pondmaster UV... | Answered on Apr 22, 2011
You can tell if the UV light is on by feeling the case surrounding the light. If it's warm the light is on.
Hope that helps,
RSMITH972278
Pondmaster UV... | Answered on Oct 14, 2009
Pondmaster pump repair part 1 - YouTube
? 3:12
www.youtube.com/watch?v=KFbe0xmk2tk
Oct 29, 2011 - Uploaded by Asianleful Pondmaster pump repair part 1 ... How to build a simple PVC Hand Pump - the Peters Pump - Duration: 20 ...
Pondmaster... | Answered on Aug 07, 2015
whatever the manual tells you
Garden | Answered Yesterday
That is usually caused by hangups in the pull starter system creating too much friction and not transferring the pull to the motor. Here is the parts diagram and exploded view
https://www.diyspareparts.com/parts/stihl/diagrams/br-380/
A single pole push button would tie the fused battery feed at the ignition switch B terminal (red/white wire) to the ignition switch S terminal (orange wire).
This provides the same function as turning ignition switch to the start position with all safeties remaining functional. For engine run the ignition switch must be in run position. Push and hold push button until engine run. Turn ignition switch to off position to kill engine.
See link below for wiring diagram located in parts section of manual.
https://www.manualslib.com/products/Troy-Bilt-Ltx-1842-2923621.html
WELL I GUESS YOU NEED TO REMEMBER WHERE YOU BOUGHTIT AND CONTACT THEM SEEMS WE MIGHT NEED TO KNOW A MAKE BUT ALASS YOU FORGOT THAT TOO
Garden | Answered 2 days ago
very interesting question
cant get at it from underneath for sure
you can buy the part
best guess is take off the engine hood and pull the whole top to bits till you get to the broken handle
Bosch ROTAK 34 Manuals
Garden | Answered on Sep 25, 2020
Though I have never heard of Yellowstone appliances, I am pretty sure there is a way to get replacement parts from the company spare parts department or from other sources who sell these pressure washers. If not, try the Internet, or try the Speed shops where they sell these to people who pressure wash their cars/trucks. I am also sure there are other hoses not necessarily for the Yellowstone brand but fit perfectly well on them. Find out where they sell other brands and take your washer to them, ask them if they can sell you a hose with the right connectors to fit your washer. No salesperson can refuse to sell you a good bargain.
Garden | Answered on Sep 24, 2020
i wouldnt even consider it. a truck mounted plow makes more sense
Garden | Answered on Sep 22, 2020
check your local home store. they sell things like this
We are the original Landa store in Portland, OR and have every Landa manual available both in digital and hard copies. If you can provide a serial number and email address I would be happy to send one of these out to you right away. You can reach me using the information below.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Garden | Answered on Sep 21, 2020
Pondmaster UV Clarifer Logo
5 questions posted
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
View Most Popular
Pondmaster Garden
  • Pondmaster Garden
Most Popular Question
no manual when purchased item
  • Garden
