20 Most Recent Tylo SUPER SPORT-U8 Heater 8 kW Questions & Answers
Call Saunatec Inc. at 888-780-4427 and ask for tech support. We have these in stock.
Dan
Technical Support Supervisor
Tylo SUPER... | Answered on Oct 13, 2011
Probably cooked the circuit board as well.
Get son to buy replacement!!!
Tylo SUPER... | Answered on Jan 08, 2010
If you can see air swirling around, then there's bound to be water moving around. Otherwise you wouldn't see anything moving. You have a small suction leak somewhere. When you don't have the heater turned on, there's less strain on the pump and therefore less of a suction leak. Assuming your heater has an auto-bypass. Use your garden hose to find the suction leak and patch with silicone or pool putty. Or replace o-rings and gaskets. Check plugs and grease ports, etc.
Pool & Spa | Answered on Nov 25, 2020
check and test air pump --look up on internet for multi-sites that show how to test
Pool & Spa | Answered on Nov 21, 2020
Hi Don.
See if this link helps you out. https://nymag.com/strategist/article/best-alkaline-water-machines-filters.htmlps you out.
Pool & Spa | Answered on Nov 19, 2020
Failure of the older heating system
Pool & Spa | Answered on Nov 17, 2020
You may have to fabricate your own.
Sunrise Simplicity 1 Parts? ' Hearth.com Forums Home
www.hearth.com > talk > threads > sunrise-simplicity-1-...
Oct 3, 2009 - Hey everyone, I have recently purchased a home with a Sunrise Simplicity 1 pellet stove, and am quickly finding that parts are almost if not ... Missing: baffles ‎' Must include: baffles
Regency Parts
regencypartsstore.com
Welcome to the Regency Parts Store a division of the Cozy Cabin Stove & Fireplace Shop. We carry a vast selection of Regency wood stove, gas stove, pellet ... Missing: simplicity ‎sunrise
Replacement Parts ' Stoves & Fireplaces ' My Fireplace ...
myfireplaceproducts.com > ca_en > replacement-parts
Items 289 - 336 of 1174 - PELLET DOOR FRAME WITH HANDLE AND GASKET WITHOUT GLASS. SKU: SE24085-02. CA$180.00. Buy. Add to Wish List ... Missing: simplicity ‎sunrise
Discontinued Manuals for Fireplaces ' Regency Fireplace ...
www.regency-fire.com > Customer Care
To download manuals, right-click on a link and choose "Save...". All manuals are in PDF format and require you to have a PDF reader installed on your computer ...
Pool & Spa | Answered on Nov 01, 2020
Google
Make model manual
Most are online. Or Google maker and phone them.
with pump off try turning shaft on back try to break loose then try if no luck bad pump motor replace
Pool & Spa | Answered on Oct 22, 2020
see if voltage from transformer if yes see if voltage from main board to display also check for cut wire to display
Pool & Spa | Answered on Oct 06, 2020
Tylo SUPER SPORT-U8  Heater 8 kW Logo
Popular Tags
3 questions posted
Top Tylo Pool & Spa Experts
john h
David Spradling
David Spradling
rogerpaul3
Level 1 Expert
Are you a Tylo Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Tylo Pool & Spa
  • Tylo Pool & Spa
Most Popular Question
shaft broke timer need replace
  • Pool & Spa
