20 Most Recent Dyson AM04 Hot Cool Heater/Table Fan - Silver Questions & Answers
2answers
Dyson fan e3 error
Hi there, it's Jack at Dyson. If your AM04 is displaying the F3 error code, I would encourage you to contact us directly so we can take some further details. When you have your machine to hand, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We can take you through some simple troubleshooting checks, and if a repair or replacement is needed, we can confirm if this is covered under our 2-year warranty. We'll look forward to speaking with you.
7/26/2018 12:40:54 AM • Dyson AM04 Hot... • Answered on Jul 26, 2018
2answers
Dyson AM04 error code E4 any suggestions
E4 and E5 codes explained finally! E4 means motor is not spinning right, or reaching correct RPMs. E5 means heater in not working right. I will provide more detains next.I had an AM05 which stopped working and it was showing E4 fault code and power light was blinking red. Occasionally as I turned it on motor would spin up for a second and then stop and fault code would display. Most of the time motor did not move. WARNING! I am an electrical engineer and have fixed countless things in my life, and I can say, taking this unit apart and putting it back together was very difficult. Do it at your own risk and of course, MAKE SURE POWER IS REMOVED WHEN WORKING ON IT.First, remove the base ring and remove big screw in the middle. Next, disconnect the plastic white ring connected to the oscillating motor drive shaft. This requires removal of a C-Clip. (don't lose it, as it's likely to fly when being removed). Now pry apart the bottom section from the rest. Be careful as there are connecting wires all still there. Next, tilt the fan forward all the way and that will expose 4 screws in the rear, and when tilted the other was, two screws in the front. Remove them all. Now, disconnect connectors and start separating parts. Here are a couple of pictures I had taken.6da61f48-67d1-449b-a6d2-72e4af5aae9c.jpgdyson-am04-error-code-e4-any-suggestions-4e2m4lzwxx0at01yzka4mbe1-2-2.jpgOf the two identical 6 or 7 pin connectors one has all red wires and the other is multicolor. When I disconnected the red one, the fault code went to E5. The red one goes to another board that has the heater circuit, so I deducted that E5 means either connections to the heater are bad, or heater is bad. I reconnected the red one and E4 came back. I disconnected the multicolor one and nothing happened, which told me the problem is there. I traced the wires and they were all going to the motor, which is further up the assembly. Getting to it was a real pain. To free the multicolor cable, you have to separate two rubber seals that allow the wires to move through an opening. If you can manage this, you can slowly get to the motor. When I turned the impeller I noticed that it was dragging, which explained the E4 code. When I turned it upside down motor spun freely and the fault code went away. So, I knew I had to fix the dragging problem, which was easy. Then putting it back together was a real pain. I recommend taking lots of pictures to remember what came from where. NOTE: There is thermal grease inter a metal heat sink. Make sure you don't wipe it off. It's essential, or heater semiconductors will overheat and fail. Also, MAKE SURE WIRES AT THE BOTTOM SECTION NEAR THE SWIVEL MECHANISM ARE DRESSED AS THEY WORE ORIGINALLY! Otherwise, they will rub and cam cause a fire. As you probably already know, there was a recall on these.Anyway, hope this helps people. I have gotten so many great tips off the internet, I figured I had to contribute some as well.God Bless.
12/31/2015 12:05:41 PM • Dyson AM04 Hot... • Answered on Dec 31, 2015
2answers
What does e8 mean on the display?
http://www.dyson.co.uk/support/am04/am04-irsbl/my-machine-is-not-working/e1-e5-e6-am04
6/4/2015 11:38:53 AM • Dyson AM04 Hot... • Answered on Jun 04, 2015
2answers
I have a dyson AM05 heater - it keeps turning itself off and showing error code E7
read manufacturingbookto check fuses
12/9/2014 12:26:55 PM • Dyson AM04 Hot... • Answered on Dec 09, 2014
My days on heat/ cool fan won't start on cool
Hi there, it's Jack at Dyson. To run your Dyson Hot + Cool heater on fan mode, you need to turn the target temperature down to 0 degrees using either the remote, or the controls on the base. The target temperature is shown on the LED display on the front of the heater. When fan mode is activated the light around the on/off button will turn from red to blue. I hope this helps, but if you'd like any further advice you're welcome to contact our experts 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
9/30/2014 6:59:09 AM • Dyson AM04 Hot... • Answered on Sep 30, 2014
Dyson hot and cold
Hi there, it's Jack at Dyson. It sounds like your heater is shutting off because the ambient temperature is higher than or equal to the target temperature you've chosen (shown on the LED display on the front of the machine): The heater's intelligent thermostat is engineered to turn the machine on only when needed when the ambient room temperature drops below the target temperature. However, we're happy to help you make sure your heater is working as intended. Please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
7/21/2014 1:06:16 PM • Dyson AM04 Hot... • Answered on Jul 21, 2014
Dyson hot cool will not turn on
Hi there Frank, it's Jack at Dyson. I'm not sure from your question if your AM05 isn't running at all, or if it's displaying an error code. However, there are a couple of quick troubleshooting steps you can try. If your machine is displaying an error code, we'd recommend unplugging it for the wall socket for 30 seconds before testing it again. This should reset the machine. However, if your AM05's LED display lights up as normal, it may not be coming on because the thermostat's target temperature is set lower than the current ambient temperature. Try raising the target temperature degree by degree using the remote or the controls on the base. You should find it will come on once you've set it to heat the room to a higher than ambient temperature. The Getting started guide I've attached may help, but if you'd like any additional advice from our experts you can reach us on 1-866-693-9766 (US), 0800 298 0298 (UK), 1-877-397-6622 (CA).
3/11/2014 6:49:44 PM • Dyson AM04 Hot... • Answered on Mar 11, 2014
Dyson hot cool AM04 fan. I purchased this on eBay
Hi Seaye, it's Jack at Dyson. Dyson appliances are engineered for use within the countries they're sold in, and we do strongly advise against importing a Dyson machine from one country for use in another. As you've mentioned, this can void the warranty, and a machine made for use in another country will not meet local legislation in Australia. Additionally, we're unable to guarantee that we'd have facilities available locally to support the machine with spares or servicing in the event of a breakdown. The Dyson Australia Support team will be best placed to help further with your enquiry, and I would encourage you to call them directly on 1800 239 766, or to email them at [email protected] Someone will be in touch as soon as possible to discuss your concerns.
3/11/2014 5:11:14 PM • Dyson AM04 Hot... • Answered on Mar 11, 2014
Dyson hot cool will not start
Hi Frank, it's Jack at Dyson. I'm sorry to hear you're having difficulty with your Dyson Hot + Cool fan heater. I'm not sure from your question if your machine isn't running at all, or if it's displaying an error code. However, there are a couple of quick troubleshooting steps you can try. If your AM05 is displaying an error code, we'd recommend unplugging it for the wall socket for 30 seconds before testing it again. This should reset the machine. However, if your AM05's LED display lights up as normal, it may not be coming on because the thermostat's target temperature is set lower than the current ambient temperature. Try raising the target temperature degree by degree using the remote or the controls on the base. You should find it will come on once you've set it to heat the room to a higher than ambient temperature. The Getting started guide I've attached may help, but if you'd like any additional advice from our experts you can reach us on 1-866-693-9766 (US), 0800 298 0298 (UK), 1-877-397-6622 (CA).
3/7/2014 4:21:25 PM • Dyson AM04 Hot... • Answered on Mar 07, 2014
Accidentally using US 120V electrical appliance in Singapore without using an electrical converter
If you are in Singapore you may be advised to buy a cheep for the time being and wen you get back home take it in to get it fixed with your waranty.
1/27/2014 7:17:37 AM • Dyson AM04 Hot... • Answered on Jan 27, 2014
Can the flavel Emberglow be fitted onto a natural marble hearth??
Of course, marble is stone, albeit a marginally softer stone than say granite, but it is still stone and fireproof.
12/1/2021 4:43:20 PM • Heating &... • Answered 5 hours ago
I need a wiring schematic for the "Goodman Dependable Ninety Two" propane furnace please
Question edited for clarity and to add the maker. The fact it is burning propane doesn't make and difference. It is still a gas furnace and the only difference is the size of the jets. The second image in this link shows a blue wire on the control board. https://www.google.com/search?q=dependable+ninety+two+wiring+diagram ..
12/1/2021 4:40:49 PM • Heating &... • Answered 5 hours ago
Gas logs: pilot and logs burn until I shut the glass doors
This doesn't sound like a thermocouple issue, it sounds like you don't have enough fresh air in the unit, is something plugged somwhere?
12/1/2021 12:42:21 AM • Heating &... • Answered 21 hours ago
Furnace series mac 1175 60,000 btu
You may need to bleed the fuel line
11/30/2021 10:41:06 PM • Heating &... • Answered 23 hours ago
Dyson AM04 Hot Cool Heater/Table Fan - Silver Logo
15 questions posted
Top Dyson Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Dyson Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Dyson Heating & Cooling
Most Popular Question
dyson hot cool will not start
  • Heating & Cooling
