20 Most Recent
Aqua Hayward Logic PS-16 Pool & Spa Automatic Control - Control System Questions & Answers
My salt generator is displaying
I had written the following, but I just ran across this answer on goldlinecontrol.com:
Why does the screen read "No Cell Power"?
No cell power is an indication that the unit is unable to detect the presence of the cell. Contact Technical Service for assistance 1-888-921-7665 (Monday-Friday 8am-8pmEST).
This site also has other FAQs that might help:
http://www.goldlinecontrols.com/Support/faq_aqualogic.aspx
My Adobe Reader isn't working, but the header on this .pdf file looked like it might contain an explanation of how the cell is powered, and that, in turn, might give you an ideal of how to troubleshoot and fix it with a voltmeter:
www.haywardnet.com/products/manuals/pdfs/Manual253.pdf
It looks like the power goes through relays, so the contacts of the relay may not be working. Sometimes you can take apart a relay and clean the contacts with electrical contact cleaner, or fine emory cloth, and sometimes you have to replace them.
This site has a manual for your unit, and may help you figure out this problem:
http://www.haywardnet.com/inground/products/displayProd.cfm?ProductID=127
Good luck, and hope this helps.
Says "no power to cell"
There is a couple of reasons to get this error message,
1. There is a circuit breaker that could have tripped out and therefore there no power to the chlorinator cell.
2. If this circuit breaker has not been tripped then the rectifier or the power transformer is faulty.
If you understand electronics then test the alternating low voltage output from secondary output on the transformer and if this is OK then check the DC voltage of the rectifier. This will determine which component is faulty.
This is a mains operated equipment and if you do not understand this, then I suggest you get a qualified electrician or pool/spa company to repair your chlorinator, because mains voltage equipment is dangerous and can kill if not handled correctly.
My aqua bot moves but the pump is not operating
ks for sharing the article, and more importantly, your personal experienceMindfully using our emotions as data about our inner state and knowing when it's better to de-escalate by taking a time out are great tools. Appreciate you read
https://mxplayer.pro/ ing and sharing your story, since I can certainly relate and I think others can too
Aqua vac will not suck
Check the filters. Also check to make sure the seal is good around the filter. Sometimes if not run for a long time the pump may need to be primed by adding water to the pump.
My pool repair guy says
BE CAREFUL! MANY ON LINE DEALERS CAN SEND DEFECTIVE OR REBUILT BOARDS OUT TO CONSUMERS. ONCE YOU PAY THEM ITS TOO LATE,
ANYTHING ELECTRONIC, YOU SHOULD ALWAYS BUY FROM A LOCAL POOL GUY YOU CAN TRUST.
