20 Most Recent
Pentair 250k Minimax Ch Ng Mv Heater Questions & Answers
Pilot light will light but won't stay lit in the
You probably need to change out the pilot generator. That is what tells the gas valve that the pilot is lit. They wear out after a few years.It's not a tough DIY but you may have to pull the burner tray which involves opening the gas line. A pool tech should be able to change it out for about $130.
I tried to light up
Thank you for posting your question here on Fixya.com.
The pilot generator that heats up while you hold in the gas valve knob is probably not putting out enough voltage to maintain the circuit once you release the knob. You'll want to get a hold of a digital or analog multimeter and set it for 2 Volts DC to confirm this. Put the black probe to the white generator lead and the red probe to the red generator lead. Make sure the heater system toggle switch and/or thermostat are turned off for now. You should read ~400mV or more. On a 2 Volt scale it will read 0.450 or so. Anything over 400 is generally acceptable. If it is not at least 400mV you should replace it. Putting in a new generator is pretty simple. Follow the metal-wrapped red and white wires from the valve down to the pilot assembly. That piece is what you want to replace. Some places will call them pilot generators; others thermocouples. Either way replacing it should fix your heater.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
My heater will not light
Do you physically see the spark or are you just hearing it. You can also take the igniter wire off of the control module and disconnect the pilot gas tubing from the gas valve. Turn the heater on and wait to see if you hear and smell gas coming out of the gas valve. If there is no gas check for 24v at the PV connection on the module. If there is voltage the problem is the gas valve. If no voltage the problem is the ignition module. If there is gas I would replace the pilot and gas tubing.
Santa Clarita Pool Heater Repair
Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
I have good pressure at the filter when operating
Does the spa have a seperate filter or valve system? Sounds like either the filter is dirty or a valve is closed. High pressure indicates a closed line and the heater will not work if there is no flow.
