20 Most Recent
Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM PUMP REPAIR KIT Questions & Answers
Jacuzzi pump shuts off after short interval.
probably heater, alot of older spas/jacuzzi have a circulation pump connected to the heater. when the heater starts to heat and gets to hot or draws too much load - it shuts down.
this happened to mine and I had to replace the heater?
How to install motor housing bracket on a jacuzzi
The 'toothed' edge goes on top with the teeth facing towards the motor. You will also notice the small support arm in the plastic is narrower than in the other areas of the bracket. That lines up with the seal plates locating tabs so everything is then lined up correctly for the insertion into the housing.
Jacuzzi pump won't shut off
The pump will not shut off until it reachs the pressure switch cut out setting. if the pump is converted for deep well with the injector in the well your not likely to get more then 40 psi. If the pressure switch is a 20 to 40 you might have to adjust the cut out pressure to 38 psi if the pump is making the maximum output pressure the line to the pressure switch is likely plugged. if that line is clear the switch is faulty,replace it. if the pump is not getting up to pressure the injector is likely plugged or greatly reduced.
Gfci overheat call for service
If you have any clamp on amperage meters, you need to see what the amperage draw on the circuit is when it is running. This will tell you if something is wrong with the pump circuit. It could be anything from a bad capacitor to an impeller obstruction.
