20 Most Recent Polaris Pb460 Polaris Booster Pump Replacement O - Ring Questions & Answers
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Polaris Pb460... | Answered on Nov 29, 2013
What is the nature of your trouble please. If you will ask a question, someone here will try to assist ...
Thanks for visiting FixYa.com
Polaris Pb460... | Answered on Jul 13, 2011
NO! You need to convert the wires to 120 as shown in the directions then wire in your 120V line and it will run normally.
John
Polaris Pb460... | Answered on Dec 25, 2010
Yeah, sounds like the bearings/bushings are shot.
Polaris Pb460... | Answered on Nov 30, 2010
Your best solution is to take it to a local small motor repair shop and have it rebuilt for under $100. Replacement is about $300. There is almost nothing you can do on your own... Sorry
Polaris Pb460... | Answered on Apr 21, 2010
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Polaris Pb460... | Answered on Apr 14, 2010
If your getting good pressure at the pump Then the next thing to check is the wall screen. It will be in the wall of the pool behind the quick disconnect fitting for the cleaner hose. This is proballoy the problem but if it is clogged it will clog again and you will need to find the cause to fix the problem. Good luck.
Polaris Pb460... | Answered on Mar 01, 2010
there is not a reset on the pump itself. It does have a high limit that shuts the motor off if it overheats but will reset on it's own when it cools down. Check to see if it might be tied in with a GFCI or a sub-breaker somewhere.
Polaris Pb460... | Answered on Nov 11, 2009
Pull the back cap off the motor and hold the shaft as you spin off the impeller. The rest is straight forward enough.
Polaris Pb460... | Answered on Sep 08, 2009
The label on the motor has a wiring diagram for both 110 and 220
Polaris Pb460... | Answered on Sep 05, 2009
Who checked the cap and how did they check it? If the cap is out the motor will buzz and not turn when started
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Polaris Pb460... | Answered on Aug 04, 2009
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Polaris Pb460... | Answered on Jun 14, 2009
Get a screwdriver (or something strong like that) that is the diameter of the pipe only. Use a torch to heat it up and then press it into the pvc...might take a couple times to get a good indent, and then turn....it is threaded 3/4" pvc....some installers will actually glue this fitting in the pump - which render it unuseable in this situation....
Polaris Pb460... | Answered on Apr 04, 2009
o.k. we will call impeller front ok ? take back cover off look at end of shaft slot for screw driver? put screw driver in slot turn impeller off .
Polaris Pb460... | Answered on Feb 11, 2009
Polaris Pb460 Polaris Booster Pump Replacement O - Ring Logo
18 questions posted
Top Polaris Pool & Spa Experts
David Spradling
David Spradling
john h
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Polaris Pool & Spa
  • Polaris Pool & Spa
Most Popular Question
booster pump only starts intermittently
  • Pool & Spa
