20 Most Recent Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out, Side Discharge, 120V Questions & Answers
How do u wire this pump grn whi black wire
There are wiring diagrams on back of each motor. US Parts Center
1/20/2018 3:05:27 AM • Aqua Flo 1 HP... • Answered on Jan 20, 2018
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
1/10/2014 6:02:42 PM • Aqua Flo 1 HP... • Answered on Jan 10, 2014
How to remove pump from motor
remove the bolts holding the suction side cover on. remove the cover on the end of the motor and use a tool (armature holding tool) to immobilize the motor shaft. remove the center screw (if applicable) in the middle of the impeller by turning clockwise. Spin the impeller off by turning counter-clockwise. If it will not come off, you may need an impeller wrench. Once the impeller is off you can remove the four through bolts and the motor should come right off.
10/31/2010 1:58:41 AM • Aqua Flo 1 HP... • Answered on Oct 31, 2010
LF READING ON PANEL
LF means "Low Flow". Remove the filters to see if the code goes away. If not, the pressure switch may be bad.
4/21/2010 6:52:30 PM • Aqua Flo 1 HP... • Answered on Apr 21, 2010
Removal of Aqua-Flo pump from motor
You will need to pull the front of the pump off then unscrew the impeller. The impeller will be set on the shaft and will take some force to break free. Hold ing the back of the shaft and using water pump pliers on the face of the impeller will usually work but sometimes I will wedge a screwdriver in the fin of the impeller and hit it sharply (not hard) with a hammer to break it free. Then the housing will just pull free of the motor. When replaceing, the impeller just goes on hand tight. Hope this helps and good luck.
4/16/2010 4:27:39 AM • Aqua Flo 1 HP... • Answered on Apr 16, 2010
Emerson 48 frame pool motor 110v 220v wiring diagram
L1 and L2 is where you hook up the two powers (lines) and the green goes to ground.. look close you will see the L1= L2 in the plastin next to the power screws
10/2/2013 6:25:51 PM • Aqua Flo Pool &... • Answered on Oct 02, 2013
I bought a new Aqua flo single speed pump but it came in as a 3400 RPM unit instead of a 1700. Can I wire the pump to a slower speed and if so how?
Probably not ... 1725 and 3400 <> are standard speeds for electric motors. See if your dealer will make an exchange for you for the proper speed pump.
12/10/2012 2:20:57 AM • Aqua Flo Pool &... • Answered on Dec 10, 2012
2answers
LifeSmart LS350 Plus Hot Tub Jet Spa. Can I convert my LifeSmart LS350 Plus 110v to a 230V
Question edited for clarity. Question moved from Computers category. Yes if you swap everything that is connected to electricity over to 220 volts. It is marketed as a 110 volt spa eliminating the problems of running 220 volt power. https://www.google.com/search?q=lifesmart+ls350+plus+220+volt ..
4/14/2024 9:55:26 AM • Pool & Spa • Answered 2 days ago
2answers
How do you clear a general fault on the power supply of Minimax NT5000 24V/15A-HR?
Contact the manufacturer 1 800 863 3930 for specific information about this. The manual does not include information for getting rid of a general fault. https://www.alpha.com/download/outside_plant_power/cableups_power_supplies/broadband_ferro/install_oper_manual.pdf
3/17/2024 4:14:55 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
My Maax 461 Spa Heater heats constant until overheat and trips out until manually reset. If jets not turned on, the heater will overheat and trip. Acts like contacts stuck?
Question edited for clarity, 'till' refers to turning over soil, 'tilling', 'until' is the word you need. That sounds like a thermostat problem. The heater should only be on when water is circulating, even if it is just in the standby mode before the high pressure jets are turned on. Contact your installer or one of the parts suppliers in the link. It is unlikely to need a new mainboard. https://www.google.com/search?q=Maax+461+Heater ..
3/17/2024 4:08:41 AM • Pool & Spa • Answered on Mar 17, 2024
2answers
What is chemistry?
Chemistry is the branch of science concerned with the substances of which matter is composed, the investigation of their properties and reactions, and the use of such reactions to form new substances.
3/17/2024 4:06:29 AM • Pool & Spa • Answered on Mar 17, 2024
I am searching for an Aristocrat manual for the spa.
https://www.manualslib.com/manual/726129/Aristocrat-Usa-Mav500-Mkvi.html
1/8/2024 4:28:34 PM • Pool & Spa • Answered on Jan 08, 2024
Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out, Side Discharge, 120V Logo
5 questions posted
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Aqua Flo Pool & Spa
  • Aqua Flo Pool & Spa
Most Popular Question
u wire pump grn whi black wire
  • Pool & Spa
