20 Most Recent Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub Questions & Answers
unplug and reprogram it
Qca Spas... | Answered on Jan 10, 2014
I need more information, is the breaker for the spa on? does it have any power, and if so is there an error code on your topside display? if you can give me some more info I'd be glad to help.
Qca Spas... | Answered on Nov 05, 2013
  1. To lock/unlock the spa, press the “set” button and then (the word “set” will be flashing) press “temperature up” button once, wait 10 seconds before pressing any other buttons.
  2. To lock/unlock the spa’s temperature, press the “set” button and then (the word “set” will be flashing) press “temperature down” button once, wait 10 seconds before pressing any other buttons.
Qca Spas... | Answered on Oct 08, 2009
The Pump pulsing is sounding like maybe there is not enough water in the spa to keep enough water to the front of the pump.
This is called 'cavatate" and is caused by lack of water to the front of the pump.
Also check the gate valves in front of the pump and the other side of the discharge of the pump to make sure they are completely open.
The Light issue sounds like maybe a relay on the circuit board could be bad or the transformer for the light is going out.
RodUS Parts Center888-521-6813
Qca Spas Pool &... | Answered on Jun 05, 2018
http://qcaspas.com/qca-spa-parts-chemicals
Qca Spas Pool &... | Answered on Aug 20, 2015
That doesn't sound good, is it 110 volts or 220? if it is 220 you can not wire it backwards. the hum might be that there is not enough power to turn it over. it could be a loose wire, bad connection, or a bad start run capacitor. if it is a capacitor it is located under the hump cover on the motor.
Qca Spas Pool &... | Answered on Jul 31, 2014
more info, maybe I can help
Qca Spas Pool &... | Answered on Jul 28, 2013
Depending on what type of flow switch is in the plumbing will determine how it is changed out.
These are usually glued into the plumbing line with no unions or gate valve on either side of it,
If this is the case for you tub then you will need to drain the tub or isolate it from the water so you can plumb in a new flow switch.
Rod
US Parts Center
888-521-6183
Qca Spas Pool &... | Answered on Feb 15, 2013
Qca Spas Paradise Series Paradise Supreme Xlp Hot Tub Logo
8 questions posted
Top Qca Spas Pool & Spa Experts
john h
Tom Chichester
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Qca Spas Pool & Spa
  • Qca Spas Pool & Spa
Most Popular Question
spa lock will not deactivate
  • Pool & Spa
