20 Most Recent RTO Mega Motion 3 Wheel Travel Pal Scooter Questions & Answers
Charge the scooter and test the volts cheap volt meter. When you hear the clicking retest. If the voltage is way down the battery is bad. If voltage is ok then and electrical component like a relay needs to be replaced. Any small electronic shop can repair it. Also, Google the model and clicking behavior to see if a turn key fix exists.
RTO Mega Motion... | Answered on Feb 02, 2017
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
RTO Mega Motion... | Answered on Feb 05, 2014
Sounds like you have a bad brake and to get it working the brake will have to be replaced sorry
RTO Mega Motion... | Answered on Jun 22, 2011
Sounds to me that all the right checks have been made...
Heres a tech Tip ,9/10 battery chargers cannot bring up a pair of dead battery's.In our case Larry thats whats happening here.There isnt enough power in the batterys to turn your charger on.
Here are some steps in testing your charger ..
1) Take the two batterys out of the scooter
2) Find your self a battery charger that you can set at a trickle charge ,this setting charges at a very low voltage
3) Trickle charge each battery to a least 50%
4) Install the batterys back into the scooter
5) Plug in your charger
Now in doing this your charger should kick on for a while ,dont worry if it shuts off .The batterys being bad is the reason for it shutting off ,we are just testing to see if your charger is working.
This should keep you out of the shop.good luck
RTO Mega Motion... | Answered on Feb 10, 2011
has power but want move has warning noise going off
RTO Mega Motion... | Answered on Oct 11, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
RTO Mega Motion... | Answered on Sep 05, 2010
have yoy checked that the battery is well pluged. meaning possitive with possitive and negative with negative. sometimes grasse is stock on the joints of electricity, so brush them with a metalic brush, that should solve the proble.
RTO Mega Motion... | Answered on Jul 30, 2010
Hi. Sounds like the circuit breaker ( over load switch ) is tripping out. If you let it sit for a few minutes, does it start to work again? Does it stop when you are driving onthe flat ground, or when you drive up a slope.
I have had cases where this happens to scooters going up a slope, usually because the circuit breaker is rated to low. Sometimes a faulty or burn't out motor will cause this fault.
Also check that the brake solenoid ( free-wheel )is releasing properly. Can you push the scooter when the brake is released?
Good luck. Neil.
RTO Mega Motion... | Answered on May 31, 2010
I have repaired a scooter with the same problem, it normally the rear part of the motor connections, like string loaded connectors, you will need to gently rough up the connecters so a good connection is made , also below the bike there are the main wiring connecters again remove the connectors then reinsert, this is normally a bad connection problem. where the read disconnects to the main scooter is the main area of connection problems.
Regards
GeWiz.
RTO Mega Motion... | Answered on Oct 17, 2009
Call Mega Motion at 1-800-634-2508, 9am to 5 pm (EST).
RTO Mega Motion... | Answered on Jun 05, 2009
It is time to replace the batteries. Buy two, not just one. This scooter takes two 12 volt, 12 amp hour, sealed deep cycle batteries. If you replace just one, the charger will not charge them properly. Take off the seat (pull upward). Turn the scooter on its side. Remove the six screws (2 in front, 2 under the foot rest, and 2 in the back. Unsnap the old batteries (one at a time) and replace with new. Be sure to keep the wiring as is, so you keep the circuit in series (not in parellel). In fact, before you remove the old batteries, label the connections (A to A, B to B, etc.) so you reconnect just as they were. Total cost is about $200. Time to replace is about a half hour.
RTO Mega Motion 3 Wheel Travel Pal Scooter Logo
22 questions posted
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
RTO Health & Beauty
  • RTO Health & Beauty
Most Popular Question
mother me pick
  • Health & Beauty
