20 Most Recent
Shoprider Sprinter Jumbo 3 Questions & Answers
Shoprider scooter what it does is that runs for
i have the same problem with my pride hurricane ,
i am looking into the throttle potentiometer to see if that is the
problem,
i will post on here if i find out,
let me know how you get on !
11/17/2014 4:13:03 AM •
Shoprider...
Answered
on Nov 17, 2014
Scooter takes off automaticaly when key is turned on
mcdevito75 here, Try to turn the key on / off a few times, the switch could be stuck, also with the key off turn the accelerator handle a few times, as it too can be stuck. If nothing and you have a warantee contact the chair manufacturer. If you have no warantee, contact any surgicall supply outlet in your area for repair options.
7/1/2010 12:56:56 AM •
Shoprider...
Answered
on Jul 01, 2010
My shoprider cobra loses speed when I am on top speed.
Hi. Does the machine do this more soon after removing the machine off the charger? When a mobility scooter is going down hill, the controller feeds the voltage generated by the motor back into the batteries. When I an testing machines here at the workshop, I have seen cases where 10 to 12 amps is going back into the batteries on a down hill run. If the batteries are fully charged or unable to take much current, the controller slows the scooter right down to limit the higher voltage generated.
It might pay to check the battery leads and connectors as well, and get the batteries tested.
While you are driving along, try moving the speed lever slowly up and down, not in and out as you normally use it. Sometimes a faulty speed pot ( wig wag ) will cause the speed to change.
Good luck. Neil.
5/30/2010 2:41:19 AM •
Shoprider...
Answered
on May 30, 2010
Push button to turn on and it just flashes and beeps
Hello,depending on what the series of beeps are & on whether it is a scooter or wheelchair.Then you can work out the problem.If you are trying to repair yourself,"please take a pic of anything before you touch on your mobile say,for relaying back to".Have a look at:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772,Download as a PDF File to view.Hope this was of help,have a nice day.Colin
