20 Most Recent Electric Mobility Pronto M41 Power Chair Electric Battery Wheelchair Questions & Answers
You have to have a Invacare Remote Programmer to plug into the joystick and program different sensitivity levels. Sorry, there is no other way to adjust the joystick. Find a store that sells Invacare chairs and see if they can program your joystick. The programmers are expensive to buy and without training with one you could easily cause your chair to really drive bad to not drive at all.
Electric... | Answered on Jan 25, 2015
The yellow wrench is a diagnostic tool. How many times does it blink between pauses. Example might be 3 blinks then pause then 3 blinks then pause, over and over. Hoe many does your chair blink?
Electric... | Answered on Jun 04, 2014
Joe See my tips on charging batteries No you don't have to leave the chair on when charging. Charge overnite after using it during the day. Always have the charger off when plugging it into the chair and unplugging from the chair. The charger you have doesn't have an on/off switch so get a power strip with the on/off switch, plug that into the wall and plug your charger into the strip use the switch on the strip to turn the charger on and off this will save you having to plug and unplug the charger rom the wall. Always store or put the chair up fully charged. If you don't use the cair daily charge at least once a week. It takes 9-10 chargings to get the batteries operating at 100% so use the chair and charge overnight while you sleep Never leave the charger on the chair more than 12 hours Hope this helps you
Electric... | Answered on May 05, 2014
Check the charger output to verify whether or not you have a bad charger using a voltmeter. These smaller batteries are notorious for having a short shelf life and poor quality control from the manufacturer. Load test the batteries after you verify you have a working charger that will bring the batteries up to the proper voltage first.
Electric... | Answered on Mar 06, 2014
8 flashes on a invacare means controller fault,please contact dealer,and have a tech look at first so they can ordor u one,recomdation take chair to dealer if u can will save u money on a house call
Electric... | Answered on Jan 19, 2014
battery is low, or battery needs to be charged, and if it won't have charger check out.
Electric... | Answered on Aug 29, 2011
Mr Witaker the 2 flashes follwed by a pause and 2 more flashes etc indicate a battery fault if you have all the battery level lights on the joystick lit up and you are sure the batteries were charged then there is a problem with one of the batteries that the controller doesn't like. try turning the chair off and letting it rest for a while then turn it back on if you still get the two flashes then I would say you need to replace the batteries Now if Medicare purchased your chair they will pay for most of the repair costs you can contact Repair Xpress Tuesday at 1-877-581-3733 to see if they have a tech in your area or call Roadrunner Mobility at 1-800-467-2668 for the techs in your area. Hope this helps
Electric... | Answered on Sep 06, 2010
The spring that applies tension on the wigwag often breaks. After removing the shroud to gain access to the throttle, back off the two allen screws (2mm) and pull off the throttle handles, remove the nut in order to replace the spring. The cost of the spring is about $4.00 compared to the complete throttle at about $250.00.
Electric... | Answered on Mar 25, 2019
spares
http://www.monarchmobility.com/servicing-department/
no idea on user guide, sorry but it looks like they do not have an online version, you could ask the above people if they have a copy. or were you could get one.
Electric... | Answered on Jul 04, 2018
Firam 250mg Buy Firam 250mg Online, uses, price, dosage, cost
Electric... | Answered on Jun 04, 2018
Electric Mobility Pronto M41 Power Chair Electric Battery Wheelchair Logo
13 questions posted
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Electric Mobility Health & Beauty
Most Popular Question
tips charging new batteries in jazzy
  • Health & Beauty
