20 Most Recent
Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Questions & Answers
Lights flashing
If your chair is in freewheel (levers on back of motors not in drive) then the light will flash. But are the lights scrolling left to right or right to left? You can check for freewheeling by trying to push the chair from behind if it moves easily then it is in freewheel and you will have to move the levers to the drive position. You need to give more info of the flashing lights are all the lights flashing are only some flashing? etc
How do I get my pronto m91 out of charging mode?
The M91 has an onboard charger. When unplugging the charger power cord from the wall outlet does not stop the chair from being in the charge mode, The charger has to be unplugged from the wheelchair wiring harness or main control module under the plastic body parts. The on-board chargers fail like this sometimes.
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
Pronto m91
You are getting a motor error code. Check motor wiring and connection to the main control box. Motor may have gotten unplugged when changing the batteries.
How do i turn on chair
The ON button is at the top front of the joystick. If this button does not turn on the red, yellow and green lights there are many possibilities as to why it is not turning on. Batteries have to be checked first for proper voltage. Then wiring needs to be checked for proper connections and fuses checked.
Whre do I find the model no. n my jazzy selet
It is usually on the serial number sticker, which can be hard to find or have been removed/fallen off. If you can find the serial number, your vendor or the Invacare Co. can tell you the model, etc.
I have the tdx sp and the wrench light is flashing
There is a problem with the remote joystick. Could be a bad connection or bad harness to the remote joystick. If harness is fine then the joystick has issues and needs to be replaced or rebuilt.Try the 4-wire harness first.
Invacare Pronto Sure Step M91.
Good day!!!!
Please try to reconnect all connectors on the board...
after that try to test the machine...if persist,please check the voltage of your battery if it is 12vdc it should have at least 11vdc and if 24vdc it should have 23vdc...if the battery is lower try to replace it..
If the battery is good the problem is on the main control board..
if that so you need to replace it..please contact your manufacturer or dealer to buy the parts you needed..
Thanks for using fixya..
Have a nice day!!!
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
