20 Most Recent Taylor 5757 Digital Glass Body Fat Scale Questions & Answers
I have a tech sl 21 on the start up the number displays just keep flashing and it wont stop help please
Taylor 5757... | Answered on Nov 01, 2016
P zero to P 9 is just a user number to set it up... Instructions for set up are:
  • Turn it on.
  • Select user number using up and down buttons (P0 is fine).
  • Hit the Set button.
  • Choose gender using up and down buttons.
  • Enter your age using up and down buttons.
  • Enter your height (goes in 1/2 inch increments) using up and down buttons.
  • Hit the Set button. (Info is now saved.)
  • When scale changes to 0.0, you can step on, and get your weight.
  • It will blink and change weight possibly for a second or two. When it stops, it shows your weight.
  • Stay standing still on the scale after your weight, and it will gon to show your bodyfat percentage, then your body water percentage.
  • When finished, you can step off, and it will turn off.
Taylor 5757... | Answered on Nov 20, 2015
try removing battery if this does not work you have a faulty weight sensor
Taylor 5757... | Answered on Jun 06, 2010
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Taylor 5757... | Answered on Oct 17, 2009
"Fitnessbalan" posted the answer to your problem -- instructions for the unit in a pdf format: http://personalcare.owneriq.net/mdownloads/500eae21-4ecd-4504-9c69-a27dc677644a.pdf
Taylor 5757... | Answered on May 27, 2009
That looks like ab INCREDIBLY long number for a model number. It looks like model and serial joined.
Calibration is factory done and can't be done at home. You have to use a Government certified weight and they are very expensive.
At home, all you do is Zero them, so at rest they read zero.
https://www.google.com/search?q=Calibrating+a+Taylor+model+52609744919105302+scale
Taylor Health &... | Answered on Jan 13, 2021
it means that it can't get a 0 point because it is unstable put it on a flat table or something and push re-zero (softly)
Taylor Health &... | Answered on Sep 30, 2020
hard to say. did they come in genuine packaging?
Taylor Health &... | Answered on Jan 08, 2020
If you need scales recalibrated, I don't know who does that work in your area. I would check with where you bought them to find out if the work can be done.
Taylor Health &... | Answered on Jan 05, 2020
Taylor 5757 Digital Glass Body Fat Scale Logo
14 questions posted
Top Taylor Health & Beauty Experts
Marvin
Marvin
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Taylor Health & Beauty
Most Popular Question
my scale starts out with 7 2 instead of
  • Health & Beauty
