20 Most Recent
Black & Decker CWV3630 DustBuster Wet/Dry Vacuum Questions & Answers
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
B andD dustbuster makes loud grinding noise. how can I fix this problem? It is a Pivot lithium 20V unit
On 20V Black and Decker hand vac I was broken motor mounts. I took a housing off with 4 screws and could see that after 2-3 seconds of running the motor would move outwards and pull the fan into another housing. There are 6 struts that the motor rests within. But they do not provide enough friction to keep the motor from moving outward. So I cleaned everything off well, and wiped it down with some acetone. Then I epoxied these struts to the motor body. I think this will work.In the photo you can see a screw. There are breaks in the plastic body that the screw would secure.You can see some struts epoxied to the motor body.
I am charging it for the first time. How can I tell if the battery is charging?
Is it a 'Computer (laptop - Notebook - Chrome Book)', the Category you posted to, or a phone, or a car battery or a Drill Battery Pack, or......................
All questions must have make model (what it is)
_Most_ chargers have lights, Red flashing for charging, Green for full. _Most_ batteries take about 8 hours to fully charge. You can see _some_ charge in an hour.
Vague answers to a vague question. Click COMMENT under my post and fill in the blanks, and we will tell you the _CORRECT_ answer :>)
