20 Most Recent Maytag Refrigerator Light Switch - C3680310 Questions & Answers
The answer to your question is no,your refridgerator will not over heat. If you don't want to replace door switch you should be able to remove bulbs to shut off lights. I would try working door switch several times to see if it's just not closing all the way. Hope this helps. Thanks
Maytag... | Answered on Nov 15, 2010
It's one of the two, eithere the socket or the switch, if your bulb works on other socket, then that just one of the two i've mentioned.
better get a continuity tester to identify which one causes the problem
Maytag... | Answered on Nov 08, 2009
No. Order a replacement from Maytag.
Maytag... | Answered on Jul 07, 2009
sounds like a bad thermostat,that tells unit when to kick on and off.
Maytag... | Answered on Jun 14, 2009
SADLY IT NEEDS TESTING DONE SO CALL A LOCAL REPAIR SERVICE
Maytag... | Answered on Nov 30, 2019
I can't find any images that show the screws, but I would suggest two fixes.
Remove the screw where the leak is and wrap PTFE tape around the screw and screw it back in.
or
Remove all the screws, remove the base and see if there is an o-ring seal that needs replacing.
https://images.homedepot-static.com/catalog/pdfimages/53/53206b43-a46b-4145-8a68-80ff87ce8ee5.pdf
But there are 4 models. You could contact Moen direct.
https://www.moen.com/garbage-disposals
Electrical... | Answered Yesterday
The PC1050 is a 2 stroke ;-)
Electrical... | Answered 2 days ago
probably not. find a manual and read it to figure out how.
Electrical... | Answered on Mar 18, 2020
I would say no. The 'touch lamp' part is the part that is the issue, and the way it does the switching. My guess is that it doesn't recognise the load of the LED lamp which is very light. For the same reason, LED bulbs don't work in car direction flashers.
Electrical... | Answered on Feb 22, 2020
Generally, the kits save you a couple hundred dollars over buying each tool separately. Plus, a tool might be included in the kit that you don't usually use but that you find to be very handy and it might become your new favorite tool
Electrical... | Answered on Feb 07, 2020
you only have 3 wires if the socket is a spur. In other words not part of a ring main. A spur comes off the ring to a single socket. The three would be live, negative and earth, but in a ring main, you have a positive in and out, a negative in and out and an earth.
video
https://www.youtube.com/watch?v=gJpS0-5JQgU
https://www.google.com/search?q=T5225+Combination+switch
Electrical... | Answered on Feb 06, 2020
Got fuel going to the injectors .....
Had the ' engine m/n invalid shut down on my 12resv Kohler generator. Off light was blinking red. Clicked the select button 3 times to clear fault and confirmed Y ...then went to the Gen set information which is a few more menu down with the arrow button. It did say 12Resv so had it blink and rest it but same thing. so rest fault again and went back to the gen set information tab and I changed it to 14resv and all cleared without out fault and tryed to hit run for a min . Ofcourse it's wrong model number so would not start but did not fault. So I went back to the Gen set information menu and put it back to the original 12Resv and it started right up without fault. I placed back in Auto and been working ever sense. Has friend had same problem and as with mine it happened on a night where power went on and off multiple times. Think its really just loosing informsiton to recognize the unit to controller and needs reset or flashed if you have the OnCue will work as well....one more thing good idea I'd not sure your battery is good over 12v to pull terminals and physically check with a multi meter should be liek 13 4 volts or so for optimal starting. Good luck this was a head ache and see others have had problem ..tony Michigan
Electrical... | Answered on Jan 22, 2020
High and Low Temperature Operation
Air temperature affects generator output. Output drops 1% for each
If the engine does not start:
1. Check the fuel tank for sufficient fuel. Refill with fresh gasoline if necessary.
2. Check the engine oil. Fill to the upper limit with fresh oil.
3. Ensure that the fuel petcock is open. The fuel petcock is open when the lever is perpendi-
cular to the ground (straight up and
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized D
service center. To locate a D
WALT service center nearest to you, call 1-800-4-D
E
Maytag Refrigerator Light Switch - C3680310 Logo
10 questions posted
Top Maytag Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Maytag Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Electrical Supplies
Most Popular Question
light stays will refridg over heat
  • Electrical Supplies
