20 Most Recent
Biostar K8VGA-M Motherboard Questions & Answers
My motherboard will not power up after the power
hi...
1.the probelm is with the power supply unit which supplies power to all the unit.check weather output is comin or not.
2.check the power cable is properly inserted in the socket.
3.the socket connecting to the motherboard is damaged.
if my answer was usefull please vote me.
How to turn off on board graphics card
get into the bios of your computer. (look it up on the internet if you don't know how) search around, there should be a setting in there for onboard graphics. most likely in a "devices" or "advanced devices". this is just off memory but keep searching and don't play around with other settings. ^^
Consecutive beeps last 10 seconds, silence for 5
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Windows setup does not see sata drive K8VGA-m
Good day sir, if your hard drive is bad it cannot be detected, but lets review first several reasons why it cannot be detected by your motherboard;
- check the master / slave setup, if youre hard drive is sata, this is not applicable.
- check your connection, both data and power cable, to and from the hard drive. (ribbon ide cable or red sata data cable)
- Still cannot be detected? try to reset your CMOS setup by using the cmos battery jumper. after reset, review the CMOS settings, and enable your IDE/SATA drives. test again.
- Stiil doesn't work? bring it to a friend who has a PC and try to test your hard drive to any available good PC, to check if your drive is bad.
If your hard drive is good, chances are your motherboard IDE/SATA part is bad, you may need to buy a PCI to SATA/IDE card. connect this card to any available PCI slot, connect your hard drive. hope this helps.
New hard drive not reconized, motherboard drivers
I had this problem on a computer recently. This particular motherboard may be needing the driver on the Windows XP SP2 disk. Your motherboard may have been made to use Microsoft SATA drivers. Othewise, there would have been a driver disk that came with the motherboard to let it see that SATA hard drive.
If it's a new hard drive, you have to reinstall the O/S so use a disk new enough to have SP2 included.
Problem with DDR
If the memory is good (test it on another comp. ) it may be possible that the motherboard does not support that type of memory (happens !! ), or it supports that quantity of memory only on one slot . U must get the motherboard;s manual and read there if they are any particularities..... (sometimes , very rarely, there are BIOS settings ...that may interfere ... )
Long Beeps every other second
Ok, I did some research into your board. Your motherboard is running an award bios.
All motherboards use beep codes to tell you what is wrong. You've got a hardware problem somewhere for sure, but where is the question. If you're having 1 long beep, with the same timing and frequency over and over then according to the codes you most likely have a memory problem. Try resetting the motherboard by resetting the cmos ( you can also do this by removing the power from the computer and taking the little clock battery off of the motherboard for about a minute).
Also, make sure your ram is tightly seated. In fact, take the ram out and then place it back in. Try running the computer with only one of the chips of ram installed (if you have more than 1 chip that is). Maybe one of the chips went bad.
Finally, here is a list of the award beep codes. If you are getting beeps that match one of these examples better than we can go from there.
1 Long, 2 Short - Video adapter failure
Repeating (Endless loop)- Memory error
1 Long, 3 Short - Video adapter failure
High freq. beeps (while running) - CPU is overheating
Repeating High, Low beeps- CPU failure
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
MP6PB M2 DRIVER
asked 1000 times learn to search here? OR
1001
GOOGLE BIOSTAR HOME
GO THERE
5/17/2022 6:39:51 PM •
Biostar...
Answered
on May 17, 2022
K8m800 am2 la motherboard schematics
there are no schematics ever.
yes mobo connectors all and more.
in the manual
learn to google first.
google Biostar home
this gets you the correct web site for you country,
then RTM.
5/17/2022 6:38:49 PM •
Biostar...
Answered
on May 17, 2022
Manual ms-7050 ver:2.0
GOOGLE BIOSTAR HOME
GO TO your countries support paGE THERE.
LEARN GO GOOGLE
FOR MANUALS OR DRIVES AND all
5/17/2022 6:25:59 PM •
Biostar...
Answered
on May 17, 2022
