20 Most Recent Ps P&s 664-lag Switch 15 Amp 120-277 V 4 Way Toggle Questions & Answers
Check that debris has not jammed the impeller. Small stone or piece of wood or wire, even a thick layer of sediment can prevent the impeller from spinning.
Electrical... | Answered 11 hours ago
i think id be looking for a short. or maybe the breaker is bad
Electrical... | Answered Yesterday
Simplest solution is to repair or replace the pull cord. Small generators are designed to be simple. The pull cord assembly and spring are usually a single combined part. They are usually fairly easy to swap yourself.
Electrical... | Answered 2 days ago
I suggest taking a close look at the starter motor - removing and testing it and while it is off check the engine will turn reasonably well by hand...
Electrical... | Answered on Sep 11, 2020
Did you try to jump the battery with another? Do that first after that the clicking is coming from the solenoid so follow the sound although that "sound" usually means it's working.
When you have the jumper battery connected and it still won't start tap on the starter. I hope this helps. Take care.
Electrical... | Answered on Sep 05, 2020
Generator voltage is regulated with a voltage regulator. Depending on what type of generator depends on what type of regulator it uses.
Electrical... | Answered on Sep 01, 2020
ask google or www.yellowpages.com
Electrical... | Answered on Aug 24, 2020
Is this a new bidet installation, USA? What year was home built and/ or remodeled?
It's probably safe but It would not be wise to use the unit without GFCI protection.
Please describe the installation. Is it plugged into a bathroom circuit with a GFCI breaker in the house panel or is there a GFCI receptacle protecting multiple outlets in the bathroom.
The typical cause for GFCI nuisance trips is an improper connection of protective equipment ground and neutral (grounded conductor) somewhere downstream of the GFCI protection device. IOTWs, a white neutral wire is touching bare ground wire or metal box.
You might try plugging the bidet into a long 3 wire extension cord so you can try a different GFCI outlet... in the kitchen or dining room. If it works at different GFCI circuits then likely it's not the unit but rather the bathroom wiring.
Comment below for further assistance.
Electrical... | Answered on Aug 20, 2020
I don't know of any 'push rose', on an internal combustion engine. Ah, you mean 'push rods' perhaps, the things that open the valves? The push rod is just a steel rod that works on a cam and presses the rocker, which presses the valve stem tip. Hopefully they just need adjusting, if not, it is a catastrophic failure!
https://www.lifanpowerusa.com/product-category/generators/energy-storm-series/
Electrical... | Answered on Jul 12, 2020
top of your electrical panel
Electrical... | Answered on Jul 10, 2020
output depends on what loads you draw on any genset
Electrical... | Answered on Jun 30, 2020
power to starter have never seen one to know if they have a solenoid for it or not
Electrical... | Answered on Jun 29, 2020
you have carb passages that are still clogged up. when you do get it all clean and running always use a little seafoam in your fuel. it works very well on small engined units... a few ozs in 5 gallons is plenty and stores very well also.
Electrical... | Answered on Jun 12, 2020
Ps P&s 664-lag Switch 15 Amp 120-277 V 4 Way Toggle Logo
0 questions posted
Top Ps Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Ps Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ps Electrical Supplies
Most Popular Question
5 ps double pole single toggle
  • Electrical Supplies
