20 Most Recent Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Questions & Answers
Replace trippers
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Or replace timer with Intematic 120 volt SPST T101 timer or T171 timer with skip-a-day
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Paragon 4001-00... | Answered on Mar 28, 2015
Humming from the timer is not normal. If the timer is still keeping the time accurately it should not be a problem. If the time is innacurate the motor may be failing. Unfortunely this timer is out of production and a replacement motor may be hard to get.
M3017-00 is the motor rated for 120VAC service or M3191-71 is the motor rated for 208/277VAC service.
You can try one of the following to source this motor if you need it.
Grainger 800-323-0620 http://www.grainger.com
Graybar 800-472-9227 http://www.graybar.com
Johnstone (5032563663 http://www.johnstonesupply.com
Munroe Electric 800-777-0172
Atlanta Supply 800-972-5391 http://www.atlantasupply.com
WestsideWholesale 18779397979 http://www.westsidewholesale.com
Paragon 4001-00... | Answered on Jan 15, 2015
heres a list of places that you can get them Grainger 800-323-0620 http://www.grainger.com
Johnstone (503) 256-3663 http://www.johnstonesupply.com
Westside Wholesale 1-877-939-7979 http://www.westsidewholesale.com
Does the manual override lever move back and forth as trippers pass? If NO, then trippers are bad
http://www.amazon.com/dp/B00441YVCO/?tag=waterheaterti-20
120 Volt timer.
When timer is ON, test across terminals 2 and 3 for 120 Volt
If 2 and 3 show 120 volt, then timer is delivering power on schedule. Look for loose connections. Loose wire nuts.
If 2 and 3 do not show 120 Volt, then timer has failed.
Suggest buy T101 as replacement for durability and generic replacement parts.
Crossover wiring from Paragon 4001-00 to Intermatic T101
Paragon 1 to Intermatic 1, Paragon 2 to Intermatic 2, paragon 3 to Intermatic A
Paragon 4001-00... | Answered on Nov 05, 2014
Use following troubleshoot table for paragon or intermatic box timers.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add comment and say what you discover, and for more assistance
Paragon 4001-00... | Answered on Apr 19, 2013
Timer not identified.
Copy following links.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#Paragon4000
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Add a comment and describe timer in detail.
Paragon 4001-00... | Answered on Apr 12, 2013
Paragon 4001-00 24-hr Timer Control 120v Ac Cd101 Logo
85 questions posted
Top Paragon Hardware & Accessories Experts
Gene Haynes
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Paragon Hardware & Accessories
Most Popular Question
paragon 4001 00 timer timer seems
  • Hardware & Accessories
