20 Most Recent UPM Remote Control Timer Set Questions & Answers
have the same model and same problem. Sometimes it connecst and sometimes not. I think they stopped making them as I can't find it on the net anywhere. Better invest in another brand
UPM Remote... | Answered on Feb 12, 2013
Press the learn button on the part that plugs in. Then press the "on" button for the remote and it should learn the code.
UPM Remote... | Answered on Dec 12, 2011
Most digital timer problems can be solved by resetting timer.
Open following link for possible instruction manual with troubleshoot steps
http://waterheatertimer.org/UPM-timers-and-manuals.html#Garrison
Check the following:
Program disable feature is not enabled.
Check 2 different sets of batteries: 1 set AA for transmitter, and 1 set button-cell batteries on back of timer
Choose between 4 different functions: programmable, photocell, countdown, or random
Using programmable mode: make sure there are no programming conflicts
UPM Remote... | Answered on Jul 22, 2011
1-800-GO-TO-UPM for technical support
UPM page for remote timers
http://www.upm-marketing.com/categories/remotecontrolsets.html
UPM used to post manuals with their product, but they evidently stopped last month, thinking that offering less would promote their product better.
I have 2 manuals for UPM remote timers:
http://waterheatertimer.org/pdf/RCT100_RT601-Manual.pdf
http://waterheatertimer.org/pdf/RC420+TR310-remote-manual.pdf
The manuals are 6 pages long and 5 pages long, making it impractical to write out all the steps without input from you.
If you review the manuals and say which one applies to your timer, and then add a comment with exactly what part of manual is confusing, and describe the buttons on your timer so I can tell which one you have, I will help further for free.
If above answer is not exact enough, or if you don't want to read the manual, then please take the simple step and pay for a fixya expert who will talk with you on the phone for a price and walk you through the steps.
Be sure to give the fixya paid expert links to manuals shown above so they will know what steps to tell you.
UPM Remote... | Answered on Dec 16, 2010
Sorry we are not able to help you with your problem
UPM Remote... | Answered on Dec 05, 2010
black is hot white is neutral should be bare or green for ground
UPM Hardware &... | Answered on Jun 07, 2018
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
UPM Hardware &... | Answered on Mar 06, 2015
Connect the timer white wire to bare ground wire.
Open following link to read instructions:
http://waterheatertimer.org/programmable.html#wire
Connecting white to ground is not 100% code, but it is not dangerous in this instance since the clock motor is less than 3 watts.
Or install battery-operated Intermatic ST01C timer that does not require Neutral wire:
http://waterheatertimer.org/ST01C-program.html#ST01C
UPM Hardware &... | Answered on Jun 25, 2012
Link below shows UPM DT420 plus manual:
http://waterheatertimer.org/UPM-timers-and-manuals.html#DT420
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
UPM Hardware &... | Answered on Jan 23, 2011
the manual says each unit has a maximum load of 3 amps (abt 7 one hundred mini light sets). when ANY INDIVIDUAL outlet is overloaded,ALL lights will turn off and an outlet overload message (OL) will be displayed. To reset,unplug unit,then unplug some of the lights in the outlet that appears to be overloaded and plug unit back in
Hardware &... | Answered on Jul 25, 2020
It's important to make sure everything is okay with your boiler. That means that it turns on and works just fine when you want it to, and in the same way it should also turn off when it needs to be turned off.
Boilers not turning off might not be a problem in your home but there certainly are some homeowners who struggle with this issue. This issue needs to be fixed right away because boilers that won't turn off could increase the risk of overheating in your home. Not only that, but you'll also find yourself paying more since your boiler won't stop running.
You can check your boiler's thermostat and see if anything changes when you try to turn the temperature levels down. If nothing happens, you should contact an expert to check the thermostat. Hiring an expert offers many advantages. Your heating system professional will also look for other areas that could be causing the issue such as the valves, the programmer, and the intricate wiring inside the boiler. These areas require the skill of an expert that's why it's best to visit the website of I-Delta to get connected with a professional who will help you.
Hardware &... | Answered on Jul 11, 2020
UPM Remote Control Timer Set Logo
8 questions posted
Top UPM Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an UPM Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • UPM Hardware & Accessories
Most Popular Question
progam
  • Hardware & Accessories
