20 Most Recent Zip Heaters Sylvania SA170 15 Amp Zip-Set Digital Wall Switch Timer Questions & Answers
My lights start blinking off and on throughout the night they are on.
Following link has troubleshoot steps for common timers http://waterheatertimer.org/How-to-troubleshoot-timers.html Gene Water Heater Timers Save Money If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
3/31/2015 2:05:31 AM • Zip Heaters... • Answered on Mar 31, 2015
0answers
2answers
SYLVANIA DIGITAL WALL SWITCH TIMER
Manual at Hardware Innovations Click manual link to right of product photo
Sylvania SA170 manual shows that timer can automatically turn on lights at sunset time, just enter your phone area code: Timer has to wired first and power on. Manual has long list of instructions starting on page 2.
How to wire timer:
SA170 replaces on-off wall switch that has 2 wires + ground
Timer has 3 wires + no ground wire
Wires that come off switch connect to Timer Blue & Black wires
Timer white wire connects with other white wires in box - if you do not have other white wires, connect to bare ground
If timer doesn't work, switch Blue and Black wires
11/3/2013 9:25:31 PM • Zip Heaters... • Answered on Nov 03, 2013
0answers
The lights that are attached
If timer worked correctly in the past, and suddenly stopped working, then manual says to push the reset button.
Following link has manual.
http://waterheatertimer.org/pdf/Sylvania-SA-170-Manual.pdf
I test timers, and most in-wall, and plug-in timers have 1 year limited warranty, although some last 5-7 years. When timers go bad, they are replaced. Sylvania is a good brand.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
5/1/2011 4:19:12 AM • Zip Heaters... • Answered on May 01, 2011
HI, I HAVE A SYLVANIA
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
12/3/2010 1:05:24 AM • Zip Heaters... • Answered on Dec 03, 2010
The Sylvania SA170 digital wall timer did not come
visit www.hardwareinnovations.com, all manuals are online
6/1/2010 1:07:48 PM • Zip Heaters... • Answered on Jun 01, 2010
Why is my heater constantly cycling
Solved the problem Thank you.
10/15/2009 5:54:59 PM • Zip Heaters... • Answered on Oct 15, 2009
Vaillant thermo compact boiler
1/6/2014 10:32:08 PM • Zip Heaters... • Answered on Jan 06, 2014
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered Yesterday
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Micromark MM 9565 Timer. How to set up the timerMM9565micro Mark timer
Question edited for clarity and add a header in order with spaces and CAPS. It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them. https://www.google.com/search?q=Micromark+MM+9565+timer ..
2/19/2024 10:55:33 PM • Hardware &... • Answered on Feb 19, 2024
How to turn water heating temperature up?
2/18/2024 9:47:44 PM • Hardware &... • Answered on Feb 18, 2024
Zip Heaters Sylvania SA170 15 Amp Zip-Set Digital Wall Switch Timer Logo
11 questions posted
Top Zip Heaters Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Zip Heaters Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Zip Heaters Hardware & Accessories
Most Popular Question
sylvania digital wall switch timer
  • Hardware & Accessories
