20 Most Recent Epson WorkForce WF-2530 Questions & Answers
What should I do if my printout is blurry or smeared? - Epson ...
https://www.epson.com/cgi.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If your printouts areblurry or smeared, try these solutions: ... If you print on both sides of a sheet of paper, smudges may appear on the reverse side of heavily saturated or dark ...Missing: every ‎10th
What should I do if my printout has lines running ... - Epson
https://www.epson.com/cgi-bin/Store/.../supDetail.jsp?...
EpsonSep 18, 2012 - Epson WorkForce WF-2530 All-in-One Printer ... If you notice white or dark lines in your prints (also called banding), try these solutions before ...Missing: 10th ‎fuzzy
FAQs for this Product - Epson WorkForce WF-2530, Top ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid...
EpsonThis link provides access to Top FAQs for the Epson WorkForce WF-2530. ... [ Answer ]; I see the message Printer is Offline when I try to print with a ... [ Answer ]; What should I do if my printout has lines running through it? .... When printing in Windows, how can I prevent an extra page from being ejected after every print job?
Epson WorkForce... | Answered on Jul 12, 2019
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Epson WorkForce... | Answered on May 13, 2019
I have the same thing. I suspect they have released a messed up Firmware :-(
I am trying to find a key combination at startup to see if that does something, the printer is otherwise completely unresponsive.
Epson WorkForce... | Answered on Dec 07, 2016
you might have to check for a maintenance kit and change the rolls.
Epson WorkForce... | Answered on Oct 21, 2016
"isn't printing" can mean several different things, each with a different cure.
If it tries to print, but no ink on paper, run a cleaning cycle and then a nozzle check.
If it just sends the paper through without trying to print on it, paper position sensor may be broken, out of adjustment, or otherwise damaged. Likely to cost more to fix than a new printer.
If it just sits there and does nothing, check self-test, print setup page. Does that work?
Epson WorkForce... | Answered on May 24, 2015
data cable is broken or the port(printer or computer) is faulty
Epson WorkForce... | Answered on May 09, 2015
Can you please try to really properly describe your problem as at present, I certainly have no idea what it could be as your description does not really mean anything.
Epson WorkForce... | Answered on Mar 15, 2015
This can happen due the printer automatically running a cleaning cycle when any new cartridge is installed, to ensure the ink is properly run into the printhead down to the nozzles. In the main, what happens is the ink that is used during such cleans goes into the Waste Pad but sits on top if the pad is fairly soaked with ink from past cleans and is thus transferred on to the underside of the printhead - thus to get smudged on to the print paper. Ideally, fit a Waste Ink Bottle (search on youtube.com for your printer model and for the Waste Ink Bottle installation - some dealers of ink cartridges offer packs with full instructions but is generally easy and cheap to DIY). All you need is some tubing to fit on the waste ink drain tubing (normally inside the RH side .- where the printhead parks between uses - the youtube video for your model will show how to easily remove the end panel and fit the tubing) and then to put the end of the replacement tubing into a small glass (not plastic as can be easily tipped over - glass is better as heavier) so any waste ink is drained from the felt waste pads under where the nozzles park. Meantime, put the printhead into the Change Cartridge position, then unplug the power lead - NOT turn printer off as that simply parks the head again. With the head in the CC position and power off, you can freely move the whole printhead with its cartridges to the left - then make a decent pad of kitchen paper and find the felt waste pad down on the RH end and press to soak away the surplus ink. Repeat several times until most ink has gone. There is then none to get back on to the nozzle area again and you should be free of the blotching. A small torch will help to see inside the printer. There is sure to be at least one youtube video for your printer on fitting the drain system but if not - try several print cartridge suppliers (not generally the sell-only eBay ones so search using google for main dealers)
Epson WorkForce... | Answered on Feb 25, 2015
Does your computer have any further information when it's connected? "Printer Error" sounds pretty generic, not a lot of detail to tell you where to look.
I would open the ink loading hatch, and check that there's nothing jammed in there, that all your ink carts are fully seated.
If nothing there, head for the back of the printer, pull the paper-handling tray out, and see if there's paper jammed in there. replace.
Pull out paper tray, make sure there is paper there, and that there's nothing jammed in there too.
When you turn it on, is there any sound, like the printer head moving back and forth?
I have a similar printer, and the error messages I see are rather more informative. . .
Epson WorkForce... | Answered on Jan 17, 2015
for iPad & iPhone you can use Epsons App "iPrint"
Wireless Printing with Epson iPrint
    Epson iPrint offers the convenience of wireless printing direct from your iOS™ or Android™ devices. With iPrint, you can easily print web pages, Microsoft® Office™ documents, photos and PDFs over your home or office network. You can also scan and save onto your mobile devices, send as an email or upload to a cloud service such as Box.net, Dropbox, Evernote® or Google® Docs™. Epson iPrint is free to download from Apple App Store and Google Play Store.
for the Mac download the latest software below:
Epson WorkForce WF 2530 All in One Printer
epson-troubleshooting-wutfveiel3ypko01ydor435x-1-0.jpg epson-troubleshooting-wutfveiel3ypko01ydor435x-1-2.jpg
Epson WorkForce... | Answered on Dec 06, 2014
If you still have the old cartridge, hold next to the new one and see if you notice a difference, such as a "protective" cover on the new one.
Epson WorkForce... | Answered on Dec 01, 2014
Epson WorkForce WF-2530 Logo
54 questions posted
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
WorkForce Epson
  • WorkForce Epson
Most Popular Question
epson wf 2530 says paper out feeds one
  • Office Equipment & Supplies
