20 Most Recent
Hansgrohe 06358620 Pressure Balance Valve w/ Scroll Handle Oil Rub Bronze Questions & Answers
How to adjust water pressure
To adjust the pressure on this type of valve you simply rotate the handle counter clockwise from the off position. As you rotate the handle it will increase the volume as you increase the temperature. Feel free to contact me at Hansgrohe. David Scarborough 1-800-334-0455.
5/7/2012 8:22:27 PM •
Hansgrohe...
Answered
on May 07, 2012
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
4/28/2010 1:14:59 AM •
Hansgrohe...
Answered
on Apr 28, 2010
How do you set up pressure balance in shower tap?
That is air in the lines you need to bleed system turn off water open highest faucet and lowest let system drain and then turn off lowest and turn water on slowly so air bleeds out the highest faucet when system is full bleed all faucets out for 5 minutes each it can take a couple of days for air to dissapate from system
11/15/2009 5:05:10 AM •
Hansgrohe...
Answered
on Nov 15, 2009
Water from bathtub faucet is orange when first turns on. The plumber says it is not rust. The pipes are all copper. It becomes clear after about 30 seconds but by the next morning the water is cloudy
identify the source from hot or from cold or from both. cold only suggests you may have a rusty water service supply pipe. this pipe is outside underground. hot would indicate corrosion at your water tou may have a copper system but it;sheater. both hot and cold would possibly indicate galvanized nipples were used to stub out of the wall under your sink, and are experiencing ionic transfer...or electrolysis...if its your bathtub you are talking about and not your sink faucet,,,,the color is very common and is occurring because your tub spout and showerhead were piped with galvanized pipe. a lot of plumbing shops pre-fab their tub valves with galvanized pipe and supply the valve water with copper tubing....just grin and bear it if so. one more idea if it is your faucet and it occurs on both hot and cold use...check the screen in your faucet aerator...the little chrome (or brass) tip that screws on and off the end of the spout on the faucet. good luck and if you see corrosion on any supply connections...handle with care...the pipe or fitting could be very brittle or soft...and break apart...causing a flood....make sure to know where and how to turn your house water supply off before going beyond a visual inspection of your plumbing..orange water indicates corrosion of steel pipe 99% of the time and bkue water indicates corrosion of copper pipe 99% of the time.
8/31/2021 3:59:22 PM •
Hansgrohe...
Answered
on Aug 31, 2021
I have a Hans Grohe
NPT and NPS are the same. Screw away! If your female thread is plastic and your male thread is metal, you must be careful not to overtighten as overtightening can crack the plastic on the female thread. Good luck, and don't forget your teflon tape. 4 to 5 wraps is good unless you have heavy duty gas piping teflon, then use less.
4/16/2017 5:03:39 PM •
Hansgrohe...
Answered
on Apr 16, 2017
How to increase water pressure
remove the screen and clean it or leave it out,if that don't work youll need to add an inline pressure increase pump,
5/25/2014 3:38:05 AM •
Hansgrohe...
Answered
on May 25, 2014
Leaking tap
This is most likely a cartridge that has worn out and needs to be replaced. Most of the kitchen faucets use cartridge number 92730000. This is available through your local dealer or online dealer. If you need further help feel free to contact me at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
5/23/2014 10:26:26 PM •
Hansgrohe...
Answered
on May 23, 2014
Fixing hansgrohe squeaky faucet
What is the model number of the faucet in question? How long has it been installed? How/where is it squeaking? If you need help identifying and resolving the squaking problem feel free to contact me at Hansgrohe Technical Services at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'd be happy to help.
11/18/2013 9:39:13 PM •
Hansgrohe...
Answered
on Nov 18, 2013
Fix leaky shower jet
If the shower head itself is leaking there may be a service kit for it. If not we can help if we know what model it is. If you need help identifying the shower head feel free to contact Hansgrohe Tech. 1-800-334-0455. Press 2 for Technical and ask for David Scarborough. I'd be happy to help.
4/10/2013 1:23:21 PM •
Hansgrohe...
Answered
on Apr 10, 2013
