20 Most Recent Magnavox 39MF412B/F7 Widescreen 39 Class 1080p LCD HDTV, 1920x1080p Display, 3 HDMI Inputs, fun-Link to Control All HDMI-CEC Devices via a Single Remote, PC Input via VGA and HDMI Ports, SRS TruSurround XT/Dolby Digital Output, 20W Total Power, 5 Band Equaliz Questions & Answers
Change language from spanish to english
Try going to your menu button or setup button on the remote. Look for the word "Idioma". That is spanish for language. Once you select ENGLISH to change, make sure you follow the exit instructions so it will be memorized
8/31/2016 3:54:12 AM • Magnavox... • Answered on Aug 31, 2016
What to adjust if text not sharp?
With a Magnavox, you just buy a new television. They are not good quality and that model is only 720P. Old tech. https://www.google.com/search?q=Magnavox+22ME601B%2FF7 ..
2/25/2024 6:25:10 AM • Magnavox... • Answered on Feb 25, 2024
Trying to use my Magnavox 15MF400T/37 as a monitor with a VGA cable, but I am having trouble finding the PC input option. Input options ar AV/TV/S-Video.
it does not have one. You cannot directly connect VGA to composite or svideo since they are two completely different and incompatible signals. However, you can use a converter like PID# 4724 or 4722 to actively convert between these types of signals. google s video to VGA apater
1/9/2024 10:32:05 PM • Magnavox... • Answered on Jan 09, 2024
My Magnavox Smart tv comes on but then sticks on one channel and it won't do anything.
Try pressing the Source button on the Remote and run through all the Input options. You can also try a full Power reset. Disconnect the power to everything for 5 minutes including the router. Plug back in, wait 10 minutes. Switch television on and try again. ..
1/4/2024 7:45:41 PM • Magnavox... • Answered on Jan 04, 2024
Need code for my TV using magnavox nb672 remote
12/13/2023 4:34:27 PM • Magnavox... • Answered on Dec 13, 2023
VCR/DVD code for a Magnavox?
Your question is lacking in details. You have an unknown make of VCR or DVD and you want the Magnavox television to operate them? Or you want the VCR and DVD remote to operate the television. Or you want a Universal Remote and a magic code to make all three work? The answer to all three is No, apart from number 3 where a very expensive LCD computerized remote can control multiple items. No one uses Universal remotes, there are better options. Codes are based on the MAKE of the unit to be operated, so Philips DVD you want a Philips DVD remote code. For the Magnavox, you want the code for a Magnavox television IF in fact it is a television and not the VCR/DVD, which now I am thinking is actually what you are after, so we end up here! https://theproductanalyst.com/magnavox-dvd-vcr-combo-remote-codes/ But better to buy a remote actually made for that unit as explained here. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
12/2/2023 12:55:29 AM • Magnavox... • Answered on Dec 02, 2023
I need to program my Magnavox remote, NA386
Visit the following page. It will help you. RC: Programming Your Magnavox Remote Control (remotecentral.com)
11/12/2023 12:24:01 PM • Magnavox... • Answered on Nov 12, 2023
2answers
I have a Magnavox clo358 universal remote what are the codes for my Magnavox DVD VCR combo
To program your Magnavox DVD VCR combo using the Magnavox CLO358 universal remote, you can try the following codes:05030675115312031321Here's how you can program the remote:Turn on your Magnavox DVD VCR combo manually.Press and hold the "Code Search" button on the remote until the indicator light turns on.Release the "Code Search" button.Press and release the mode button for the device you want to program (in this case, the DVD VCR combo). The indicator light should remain on.Enter one of the codes listed above using the numeric keypad on the remote. The indicator light should turn off after entering the code.Aim the remote at the DVD VCR combo and press the "Power" button. If the device turns off, the code is correct. If not, repeat steps 4 to 6 with the next code on the list.If none of the codes work, or if you have any other issues, it's recommended to consult the user manual of your Magnavox CLO358 universal remote for additional instructions and a complete list of codes.
8/28/2023 5:54:07 PM • Magnavox... • Answered on Aug 28, 2023
Magnavox VHS/DVD writer. I have E1 error on my display, the DVD player door won't open or close on its own.
It is a known issue
My vcr has a trouble code of E1 what does this mean
JustAnswer https://www.justanswer.com > Electronics Question Nov 26, 2018 - That error code very generally means that the signal input on the rear side of the VCR is not sensing any signal input. So the first thing to do ... 1 answer ยท Top answer: Hi, thank you for contacting JustAnswer.com. My name is***** will do my best to provide the ...
MAGNAVOX DVD/VCR ZV420MW8 error code E1
Fixya https://www.fixya.com > support > t14967799-magna... Nov 11, 2012 - "E1" is the display indicator the unit is looking for a External input signal or Line Mode. "E1" External input on the rear, "E2" External input ...
7/16/2023 6:54:32 PM • Magnavox... • Answered on Jul 16, 2023
I have Magnavox DVD combo remote controls and I wanna be able to use them to control my Magnavox TV from 07 NB183 and NB555
No you can't do that. The DVD remote is single frequency. The only multi-use remotes are those that come with cable and satellite boxes, or high end universal remotes with an LCD Screen. The television remote may control another Magnavox device, but it is a budget make. https://www.google.com/search?q=Magnavox+NB183 https://www.google.com/search?q=magnavox+nb555 ..
6/12/2023 6:44:39 PM • Magnavox... • Answered on Jun 12, 2023
No sound on one channel on my magnavox tv
Is this with all sources?
5/17/2023 9:02:44 PM • Magnavox... • Answered on May 17, 2023
Magnavox Flat Screen Television. How to get rid of diagonal lines on it please?
Various ideas in the link. It is a budget brand though, so depending on age it may just be time to upgrade. https://www.google.com/search?q=diagonal+lines+in+a+Magnavox+flat+screen+tv
4/11/2023 2:50:53 AM • Magnavox... • Answered on Apr 11, 2023
What are the dish remote codes for a Magnavox soundbar??
But a new replacement remote for 12 bucks! https://www.google.com/search?q=magnavox+soundbar+%26+wired+bass+msb4550+replacement+remote+control Dish Remotes are made to work with televisions not sound bars. ..
4/4/2023 5:39:03 AM • Magnavox... • Answered on Apr 04, 2023
What code is needed to get a Dish remote to pair with a Magnavox soundbar msb4550?
Magnavoxsound bar codes 0110, 0115, 0044, 0058, 0086, 0091, 0018, 0116, 0123, 0126, 0040
4/3/2023 10:17:56 PM • Magnavox... • Answered on Apr 03, 2023
Need Repair Help with a Phillips Magnavox TV Model 15MF605T/17
It is possible that the main board of your Phillips Magnavox TV Model 15MF605T/17 is damaged or blown. However, before assuming that the main board is the problem, you can try a few troubleshooting steps:
  1. Check the connections: Make sure that all the cables and connectors are properly connected to the TV and the power source. Disconnect and reconnect all cables to ensure that they are secure.
  2. Reset the TV: Unplug the TV from the power source and wait for a few minutes. Then plug it back in and turn it on. This can reset the TV and fix any software issues.
  3. Test with another power source: Try plugging the TV into a different power outlet or using a different power cable to rule out any issues with the power source.
If none of these troubleshooting steps work, it is possible that the main board is damaged and needs to be replaced. You can contact a professional repair service for further assistance or consider purchasing a new TV if repair costs are not feasible.
3/18/2023 5:58:14 PM • Magnavox... • Answered on Mar 18, 2023
Magnavox 39MF412B/F7 Widescreen 39 Class 1080p LCD HDTV, 1920x1080p Display, 3 HDMI Inputs, fun-Link to Control All HDMI-CEC Devices via a Single Remote, PC Input via VGA and HDMI Ports, SRS TruSurround XT/Dolby Digital Output, 20W Total Power, 5 Band Equaliz Logo
3 questions posted
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Televison & Video
Most Popular Question
change language from spanish english
  • Televison & Video
