20 Most Recent Magnavox MDR537H/F7 DVD Recorder 1TB Hard Drive with Digital Tuner, Records up to 1252 hours of contents onto 1TB HDD, 4-Way Dubbing HDD->DVD, DVD->HDD, DV->HDD, DV->DVD, Watch, Forward, Rewind or Freeze Live TV while Recording; 1080p Up-Conversion, Maximum 3 Questions & Answers
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
10/23/2014 11:05:58 PM • Magnavox... • Answered on Oct 23, 2014
How connect Magnavox DVDR to Comcast Cable Box ?
You'll need to use the direct input on the rrcorder from the DVR video output.Some channels won't record as they're encoded
10/1/2014 11:50:09 PM • Magnavox... • Answered on Oct 01, 2014
Magnavox MDR537H/F7 -- DEAD no power
There is usually an internal fuse in all audio/video equipment and it will normally be a 20mm glass one positioned near the power supply or somewher close on the circuit board. There may be more than one so have a good check around. Be sure to replace with the same type and rating, no sticking kitchen foil across it to short it out, this illegal and DANGEROUS.
6/29/2014 10:02:15 AM • Magnavox... • Answered on Jun 29, 2014
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
6/3/2014 9:09:49 PM • Magnavox... • Answered on Jun 03, 2014
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
4/5/2014 3:55:56 PM • Magnavox... • Answered on Apr 05, 2014
My dvd recorder will not record and/or it burns the disc when I do not want it to. It is showing an E4 error message and this error code is not in the manual so I can not figure out what is wrong
E4 is a fault code not an error message. It means there's something wrong with the device. You need to take it to be serviced.
3/11/2014 2:09:00 AM • Magnavox... • Answered on Mar 11, 2014
CAN I WATCH A SHOW FROM THE HARD DRIVE WITH OUT RECORDING IT TO A DVD
Yes you can. That is exactly what a DVR is made for.
1/20/2013 3:01:00 AM • Magnavox... • Answered on Jan 20, 2013
How do I find the up and down button on the Magnavox remote
The up and down button on the Magnavox remote is located on the top of the remote, just below the power button. To use the up and down button, simply press the button in the direction you want the volume to go. For example, to turn the volume up, press the up button. To turn the volume down, press the down button.
11/21/2022 11:15:00 AM • Magnavox... • Answered on Nov 21, 2022
Is a 55 Magnavox LED Wifi Smart TV, model # 55MV314X/F7 Bluetooth Capable?
https://www.manualslib.com/manual/884359/Magnavox-55mv314x.html
11/10/2022 9:23:32 PM • Magnavox... • Answered on Nov 10, 2022
Can I get Hulu on my Magnavox smart TV.
You will probably have to download it to your computer, then transmit it to the TV.
9/18/2022 4:35:14 PM • Magnavox... • Answered on Sep 18, 2022
How do i setup my trinitron (kv-27fv300) remote to control my vcr/dvd player as well?
Unfortunately, you may not be able to do this. Most remote controls only have the codes for devices released about 6 months before the remote was programmed. The KV-27FV300 manual has a copyright date of 2002. Thus its remote codes are for devices made in 2001 or earlier. The DV220MW9 was built around 2009; so a universal replacement remote is probably more likely to work. To program the remote for the KV-27FV300, press Code Set (bottom left of the remote, below the volume +/- keys). Press the VCR/DVD function button. Press the number keys for the 3 digit code for the device manufacturer. Press Enter to save the code. Then test the code to see if it allows the remote to correctly control the VCR/DVD. The DV220MW9 has built by Funai with the Magnavox name plate. There are only Funai and Magnavox VCR codes in the TV manual. Funai: 338, Magnavox 308, 309, 310 . The directions for programming the remote are in the KV-27FV300 manual. That manual is available on the support page: https://www.sony.com/electronics/support/product/kv-27fv300/manuals . The current link to the manual is https://www.sony.com/electronics/support/res/manuals/W000/W0006281M.pdf . See page 49 (page 56 of the PDF) for the procedure and the code list. I hope this helps. Cindy Wells
7/1/2022 12:38:15 AM • Magnavox... • Answered on Jul 01, 2022
Laser power where to adjust magnavox zv427mg9a
The reason you can't find how to do it in the service manual is it's not something that's adjustable. Most likely it's a focus issue but that also isn't an adjustment as it's built into the logic program, it's time for a new player
6/26/2022 11:00:49 PM • Magnavox... • Answered on Jun 26, 2022
My magnavox flat screen tv is stuck on a blue screen wont let me change channels or volume and wont let me in the setting it's just stuck on a blue screen how can I fix the problem
Hi Ken, you eeprom has corrupt data, the IC can be replaced but it requires advanced soldering skills and the equipment to do it, best thing is replace the main board,
5/7/2022 2:16:12 PM • Magnavox... • Answered on May 07, 2022
Magnavox MDR537H/F7 DVD Recorder 1TB Hard Drive with Digital Tuner, Records up to 1252 hours of contents onto 1TB HDD, 4-Way Dubbing HDD->DVD, DVD->HDD, DV->HDD, DV->DVD, Watch, Forward, Rewind or Freeze Live TV while Recording; 1080p Up-Conversion, Maximum 3 Logo
11 questions posted
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Televison & Video
Most Popular Question
  • Televison & Video
