20 Most Recent Saniflo 013 Sanibest Pro Grinder Series Pump Only - Bathroom Toilet Two Piece Toilet Questions & Answers
Local authority state saniflow may choke at rainwater trap and will not accept saniflow going into rainwater drain
Your description sounds like plumbing from before bacteria was discovered. The output from a Saniflo macerator should be sent to a foul drain or cesspit and not a rainwater drain. Some authorities allow local rainwater runoff into foul drains but this situation is gradually being designed out. Could be your Saniflo installation didn't meet building regulations when it was installed. The fact it has been working fine for 2 years doesn't count for anything if it doesn't.
2/3/2018 2:40:25 AM • Saniflo Plumbing • Answered on Feb 03, 2018
Why does it leak from the top outlet?
  1. SANIFLO upflush toilet - YouTube
    ? 6:14 www.youtube.com/watch?v=-F1v6GIbWF8
    Aug 10, 2011 - Uploaded by Regis Saragosti Saniflo is the leader and inventor of the macerating toilet. ...Liberty Pumps Ascent II 1.28 GPF Macerating Toilet System - Install a Bathroom ...
7/14/2015 10:49:41 PM • Saniflo Plumbing • Answered on Jul 14, 2015
Saniflo says the bottom of shower should be 8" from floor. But what is the lowest the shower can be and still function ok?? Will 5" give enough slant? Or, how high does the water get in the sanibest u
Sorry but they give you 8" for a reason, they did the testing etc. You might get by at 5" but that will probably just get by and limit the service life.
11/27/2014 9:30:38 PM • Saniflo Plumbing • Answered on Nov 27, 2014
Saniflo undersink macerator keeps trying to pump every 10 seconds or so.
The "tank level" switch is stuck on. You may be able to clear it by cleaning the system/pump with a water hose (outside of course) so you will have to take the system apart then give it a good cleaning. May not help but at least you will have tried.
10/7/2012 2:24:10 AM • Saniflo Plumbing • Answered on Oct 07, 2012
I have a Saniflo which
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
3/2/2011 11:44:36 PM • Saniflo Plumbing • Answered on Mar 02, 2011
When pump shuts off,there is
The sound you are hearing is the check valve.
Usually this valve is just above the pump.
It's nothing to be concerned about, it's a normal
noise, or it's the nature of the beast.
All my best to you.
LeRoy
11/10/2010 10:17:19 AM • Saniflo Plumbing • Answered on Nov 10, 2010
I have a shower tray and a toilet fitted to a
need more info
3/29/2010 10:10:08 PM • Saniflo Plumbing • Answered on Mar 29, 2010
I HAVE A NOISEY PUMP COULD YOU TELL ME THE
First possible cause which comes to mind is a failing motor bearing. Try lubricatng the bearing and see if the noise changes.
Second could be the impeller breaking apart.
3/24/2010 9:52:45 AM • Saniflo Plumbing • Answered on Mar 24, 2010
I HAVE A PROBLEM WITH A PUMP FOR A SANIFLO
sounds like the pump is jamed with toilet paper or wipes.
You will have to take out the pump to un block it
8/23/2009 12:35:06 PM • Saniflo Plumbing • Answered on Aug 23, 2009
How can I fix a Moen faucet 1225 in the kitchen?
Question edited for correct spelling of maker 'Noen' to 'Moen'. 'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Moen One-handle Replacement Cartridge -- 1225
MOEN https://www.moen.com > products > Moen > 1225 From finishes that are guaranteed to last a lifetime, to faucets that perfectly balance your water pressure, Moen sets the standard for exceptional beauty ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.4 · ‎ 31 reviews · ‎ US$33.35
M-Line Moen cartridge -- M1225
Moen https://www.moen.ca > products > M-Line > M1225 Moen Cartridge · Designed for 1 Handle lavatory, kitchen and tub/shower faucets (after 1959) · Replaces O.E.M. 1225 · Backed by MOEN's limited lifetime warranty.
MOEN #1225 Single-Handle Faucet Cartridge
Home Depot https://www.homedepot.ca > ... > Faucet Cartridges It maintains a balanced pressure of hot and cold water. This cartridge assembly is ideal for Delta Monitor 1300 and 1400 series tubs and showers. See less ... In stock
Moen 1225 One-Handle Kitchen and Bathroom Faucet ...
Amazon.ca https://www.amazon.ca > Moen-1225-One-Handle-Repl... Replacement faucet single control cartridge; Fits all single-handle kitchen, lavatory, tub, and shower Moen and Stanadyne faucets; Eliminates hard pull ... "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(62px);"> Rating: 4.6 · ‎ 5,065 reviews · ‎ $33.34 · ‎ In stock ..
3/25/2024 10:23:56 PM • Plumbing • Answered on Mar 25, 2024
2answers
Do you give memenars about pumps
Well, we can have a one on one seminar by the internet.
I've been a pumpman for 20 years. I can share with you
my experience (household pumps, suibmersible pumps,
turbine pumps, gear pumps, piston pumps, dewatering
pumps, mud pumps, trash pumps, mining pumps,
solids handling pump, etc....) Just take your pick. Just
send in your e-mail for assistance. God bless.
1/17/2024 9:59:21 AM • Plumbing • Answered on Jan 17, 2024
Structured Flow model SL110B single lever shower faucet. How can I get the cap off the stem to adjust the stop?
Hex set set screw bottom side of handle hub. I see no adjustments... likely you will need to replace the cartridge.
http://structuredflowfaucets.com/wp-content/uploads/2016/12/912090B.pdf
1/13/2024 1:45:45 AM • Plumbing • Answered on Jan 13, 2024
I need the spray head diverter that spreads out the spray - it snaps onto the front end.
Posted to Home Plumbing category, so one of these https://www.google.com/search?q=vintage+sprayer+spray+head+diverter Or Garden Sprayer like this? You can get a vintage new wand on eBay. https://www.google.com/search?q=vintage+garden+sprayer+nozzle All questions need FULL 'make model (what is is)' as first 3 words. ..
11/26/2023 12:59:53 AM • Plumbing • Answered on Nov 26, 2023
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets. Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
11/18/2023 1:01:01 AM • Plumbing • Answered on Nov 18, 2023
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
10/28/2023 9:12:22 PM • Plumbing • Answered on Oct 28, 2023
2answers
Acrylic sheet
Hello. You can heat it up with a torch along the bend line and bend it. Be careful as it get HOT. Joe
10/19/2023 9:44:08 AM • Plumbing • Answered on Oct 19, 2023
My Mirolin bath drain stopper had a spring, which went down the drain when I removed the stopper to clean. Now I'm not sure how the new spring I bought goes back on.
This seems like a system which is proprietary to them, so best to ask their Support staff https://mirolin.com/contact-us/ You could have retrieved the old spring with a flexible magnetic reach tool. https://www.google.ca/search?q=magnetic+pickup+tool https://www.google.com/search?q=Mirolin+bath+drain+stopper ..
10/10/2023 11:30:47 PM • Plumbing • Answered on Oct 10, 2023
Kitchen sink hose broken button nozzle
9/14/2023 5:02:50 AM • Plumbing • Answered on Sep 14, 2023
How do i fix getting water to come out of the faucet ?
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
9/12/2023 6:09:20 AM • Plumbing • Answered on Sep 12, 2023
Gnutti Sebastiano thermostatic mixing valve 1559-6I. Where can I get a new one please?
Question edited for clarity. Question moved to plumbing. Not a very well known brand. It has TWO Employees!! https://www.datanyze.com/companies/gnutti-sebastiano-figli-spa/25986208 Try here. They are U.K. based.
Thermostatic Cartridge for GS Groupo Gnutti Sebastiano ...
Di Vapor https://www.divapor.com > thermostatic-cartridge > th... Thermostatic Cartridge for GS Groupo Gnutti Sebastiano 7421 For All Thermostatic Mixing Valves - Small 20 Pt Stem. Part Number: GS-7421. Price: £199.95. £149.83 More here https://www.google.com/search?q=%22Gnutti+Sebastiano%22+thermostatic+mixing+valve ..
8/19/2023 2:47:11 PM • Plumbing • Answered on Aug 19, 2023
Saniflo 013 Sanibest Pro Grinder Series Pump Only - Bathroom Toilet Two Piece Toilet Logo
1 questions posted
Top Saniflo Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
View Most Popular
Saniflo Plumbing
  • Saniflo Plumbing
Most Popular Question
six months ago sanicompact developed low
  • Plumbing
