20 Most Recent Samsung Chromebook Series 3 Questions & Answers
2answers
Won't sign onto wifi network
try reset the wifi device (modem or router)...then restart the chromebook....then try to sign in again...
1/21/2016 10:09:58 PM • Samsung... • Answered on Jan 21, 2016
How do i tranfer my photos from sumsung chromebook to usb
I'm not familiar with the Chromebook OS but I'm assuming that you should be able to copy and paste them if it doesn't have a programme or app you can do it from. 1. Insert your usb device (your chromebook should recognize this as an additional drive). 2. Open the folder with the photos you want to transfer select *copy then open the window for the usb drive and select *paste (*usually commands found when you right click on a mouse).
2/25/2015 11:28:38 AM • Samsung... • Answered on Feb 25, 2015
The @ symbol won't work and will only print as a apostrophe
Try using the ALT Car key to the right of the space bar.
11/25/2013 11:16:25 PM • Samsung... • Answered on Nov 25, 2013
What does error code Ee with the degrees Fahrenheit showing mean on a Samsung RF26HFENDSL Refrigerator ?
Error code Ee with the degrees Fahrenheit showing on a Samsung RF26HFENDSL refrigerator typically indicates a communication error between the refrigerator's main control board and the temperature sensor. This error can be caused by a faulty temperature sensor or a problem with the main control board. It's recommended to check the sensor wiring and connections or call a professional to check the main control board.
1/25/2023 5:09:03 PM • Samsung... • Answered 3 days ago
Redundant wire on Samsung American FF
Samsung American FF redundant wiring connector?
Subscribe
Bazza's profile photo
Bazza
unread,
3:59 PM
to
Took delivery last week of a model RS6aA8830S9 and had to hake the freezer door of to get it in the kitchen. No prpblems there whatsoever.
Put the door back on OK and then started to connect up the wiring connectorsI connected up two pairs with their unique matching Male and Female partners.
Then the next two connectors went in to their unique matching connectors under the hinge cover. Oner of these was obviously for the beeper.
Because each pair is unique in terms of size, shape and number of pins, there is zero possibility od a mismatch.
This left one terminal wire with its 5 pin connector that had no apparent corresponding connector.
Raise this question with Samsung and so far after 3 contacts have not had a sensible answer from them. They recommended at one stage that I organise one of their techcicians/installers to come around - at a cost of £114 which I declined.
1/16/2023 7:31:18 PM • Samsung... • Answered on Jan 16, 2023
I have Samsung syncmaster 733NW monitor. Dull display comes and goes sudennly when power ON.Blue light is glowing continuous. how to rectify
The issue you're describing with your Samsung SyncMaster 733NW monitor could be caused by a few different things. Some possible causes include a problem with the monitor's backlight or inverter, a malfunctioning video cable, or a software issue. Here are a few steps you can try to troubleshoot the problem:
  1. Check the video cable: Make sure the video cable connecting the monitor to your computer is securely plugged in on both ends. If the cable is loose, the monitor's display may be affected.
  2. Check the power cable: Make sure the power cable is securely plugged into the monitor and the outlet. Try a different outlet or power cable to rule out any issues with the power supply.
  3. Check the monitor's settings: Make sure the monitor's brightness and contrast settings are set correctly. You may also try adjusting the resolution or refresh rate to see if that improves the display.
  4. Try a different monitor: If you have another monitor available, try connecting it to your computer to see if the problem is with the monitor or the computer.
  5. If none of the above steps resolve the issue, it may be a hardware issue. It could be a problem with the backlight or inverter, which would require repair by a professional. It could also be a problem with the monitor's main board.
If none of the above steps helps, it would be better to contact the manufacturer or a authorized service center to repair it.
1/12/2023 1:07:29 PM • Samsung... • Answered on Jan 12, 2023
I have a Samsung SRS702GDHSS fridge. After moving, the refrigerator is plugged in to start, the circuit trip.
The breaker needs to be reset for your fridge or needs to be replaced.
1/7/2023 9:04:21 PM • Samsung... • Answered on Jan 07, 2023
My Samsung ST500 is not turning on
It's possible that the battery may have lost its charge after being unused for such a long period of time. I recommend trying to charge the battery for a few hours and then attempting to turn the camera on again. If the camera still does not turn on after the battery is charged, there may be an issue with the battery or the camera itself. If the battery is not the issue, there are a few other things you can try: 1. Make sure that the camera is not in "sleep" mode. If the camera has been inactive for a long period of time, it may enter sleep mode and appear to be off. Try pressing the power button to wake the camera. 2. Check that the memory card is properly inserted and seated in the camera. If the memory card is not properly seated or is corrupted, the camera may not be able to access it and may not turn on. Given this point, try to recover data from the corrupted memory card using data recovery software, such as iBoysoft Data Recovery (https://iboysoft.com/), a professional file retrieval program that can be used to recover deleted or lost data from different types of storage devices (HDDs, SSDs, SD cards, USB flash drives, memory cards, etc.). 3. Check for physical damage: Inspect the camera for any visible physical damage, such as cracks or dents. 4. If none of the above steps resolve the issue, there may be a problem with the camera's hardware. In this case, it is recommended that you contact Samsung customer service for further assistance.
12/31/2022 4:15:46 PM • Samsung... • Answered on Dec 31, 2022
Samsung syncmaster p2770h screen goes black after 1 or 2 sec.
My P2770 HD goes on, watching TV, then turns to black screen. The red LED light is on but not blinking, and the screen can be viewed under fluorescent lighting, but only at about 5% of normal. Should I assume the power inverter board has gone bad?
12/28/2022 8:27:11 PM • Samsung... • Answered on Dec 28, 2022
2answers
I'm trying to pair my Samsung TV thru my TaoTronics wireless 2 in 1 adapter to my beats pill. Please help
Hello, it is not difficult to achieve this purpose, you need a simple adapter, I will link a video that has a better graphics explanation about it. I thank this friend blog that gives us this information as well as its channel. https://tampatec.blogspot.com/2015/08/how-to-connect-bluetooth-headphones-or.html
12/23/2022 8:16:04 PM • Samsung... • Answered on Dec 23, 2022
How do you update a Samsung Giga JS8000?
Question edited to toss in a few Caps. Mentioned in the Manual https://www.manualowl.com/m/Samsung/MX-JS8000/Manual/478142?page=27 ..
12/14/2022 7:26:43 AM • Samsung... • Answered on Dec 14, 2022
Set up my JVC sound bar on a Samsung TV
Google JVC (model) manual and set it up again. The problem must be the sound bar settings not the television settings, UNLESS you reset it via the television. https://www.google.com/search?q=how+to+set+up+jvc+soundbar+to+tv ..
12/5/2022 5:57:50 PM • Samsung... • Answered on Dec 05, 2022
3answers
I want to download software
please visit below link & download software.
www.filebowl.com/samsung-wave-525-review-on-phone-arena.htm www.umnet.com/phone/4082-Samsung_Wave_525_GT_S5250 www.samsung.com > Mobile Phone > Style
11/24/2022 11:15:54 AM • Samsung... • Answered on Nov 24, 2022
Display screen won't go any further than Samsung logo
Hi, please detach all non-essential devices from the computer and attempt to load it again. If the boot doesn't go past the logo again, you can use a combination of windows and f8 or press ctrl , alt and delete simultaneously to try and get into safe mode from startup on your screen. Once in safe mode, you might want to perform a system restore to a date prior to when this issue started. Thank you.
11/9/2022 9:10:28 AM • Samsung... • Answered on Nov 09, 2022
2answers
How do I fix my samsung UN55TU7000F TV stuck in a bootloop?
Hi, Please perform a factory reset on the your samsung tv and double check that all of the accessories have been removed. You'll also want to make sure that your remote isn't causing the issue by stashing it in a drawer pointing away from the tv. Thank you.
11/6/2022 12:27:47 PM • Samsung... • Answered on Nov 06, 2022
Samsung Multixpress K4350LX system recovery. samsung smart ux center
Contact HP https://support.hp.com/gb-en/document/c05626007
11/6/2022 5:45:15 AM • Samsung... • Answered on Nov 06, 2022
Samsung Chromebook Series 3 Logo
7 questions posted
Top Samsung Computers & Internet Experts
Marvin
Marvin
Fix It Fast...
Fix It Fast...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
tranfer photos from sumsung chromebook
  • Computers & Internet
