20 Most Recent
LG Motion 4G MetroPCS Questions & Answers
My LG Motion won't turn back on.
Did you tried to check your battery connections ? If not, remove your battery and clean the battery connections and then re-insert it. If the problem is still there, try a hard reset.
Battery won't fully charge.
Does the battery % stop at 85% or does it get to 100% and reduce to 85% when disconnected? I've read several articles about battery charging and several have stated that when the phone hits 100% on the charger it will slowly decline even though it is left connected. Basically, it hits 100% and acts like it's disconnected (even though connected). When disconnected the battery percentage will drop. I'm not sure if this is what you are experiencing or if it's a problem with the device.To start, I would suggest backing up all data on the phone and sync with Google. Perform a factory reset and log back into the device. This may solve the problem. If not, then I'd suggest going back to your service provider
Screen wont unlock
touch screen digitizer may be defective. a cellular store should be able to verify.
