20 Most Recent Yamaha HTR 5930 - AV receiver - 5.1 channel Questions & Answers
Check for problem in fuel system - bad fuel - filter - carb/throttle body etc
Yamaha HTR 5930... • Answered on Feb 25, 2021
Hello there A combination of 'standby' and 'straight' buttons You follow the procedure on page 65 of the user guide available to download here if you have lost it. http://download.yamaha.com/search/result/?site=usa.yamaha.com&language=en&search=HTR-5930
Yamaha HTR 5930... • Answered on Sep 24, 2014
Hi. I have rxv773 and it had the same problem. If u turn it on and after reley clicking 2 times fast and 1 time after about 8 seconds, look at the display if you see speaker ikons. If u don't see them and there is no sound. You wait those 10 minutes when sound comes back and look if the icons apear at the same time you got sound. If that is the case, you have bad DSP chip inside on the hdmi board. You could open the yamaha cover and see it right away on the top board at the right side. The chip is D80YK113CPTP4. That is the bad one. If you apply a heat for about 20 to 30 seconds with the heat gun at medium settings, you could fix the problem for a day or two or maybe a month. You need to replace the chip with newer one D80YK113DPTP4 . That dptp4 is updatet chip from cptp4. You can find those on aliexpress.
Yamaha Audio... • Answered on Apr 04, 2021
never had a cap that would fix itself been doing fixes with electronics for 60 yrs
Yamaha Audio... • Answered on Mar 28, 2021
Here is the User Manual of R-N803 Check Restore Setting Page 53 Link: https://usa.yamaha.com/files/download/other_assets/8/976638/web_ZX95350_R-N803_R-N803D_om_URL_EnFrEs_A0.pdf If this work for you, Please Subscribe Our YouTube Channel: CCTV Networking Technical Support and website: https://www.doitek.net
Yamaha Audio... • Answered on Feb 03, 2021
On Yamaha's official website then for the remote that you need.
Yamaha Audio... • Answered on Jan 24, 2021
Remove the short that is causing the protection to engage, then power cycle, assuming it's a short circuit protection. If it's going in to thermal protection, then shut the receiver off and let it cool. If all speaker wires are disconnected and the unit is cool to the touch but still appears to be in protection mode, likely one of the output transistors has failed an will need to be diagnosed and replaced. Don't neglect to check the ESR of the electrolytic capacitors if you find a failed device internally.
Yamaha Audio... • Answered on Jan 14, 2021
I have seen several things that can cause this. One is a capacitor that holds the memory in the cpu. Another is a voltage regulator and then there are failures in the final amplifier transistors
Yamaha Audio... • Answered on Nov 24, 2020
Unplug all your speakers and components. Then turn on, if it still locks up you have one of maybe 5 safety features hooked up that are built in to stop your amp from blowing. You will need to replace board or have some cool tech dude desolder and isolate . Look for wiring diagram for safety shut down system. Sorry but if it doesn't do it after you disconnect every thing then check each speaker with ohm meter to read factory specs.
Yamaha Audio... • Answered on Nov 10, 2020
Yes but only limited functions! like Volume and on and off.
Yamaha Audio... • Answered on Nov 08, 2020
I bought a damaged rx v1 to repair it and I measured everything and according to the voltages it is ok but and repair it
Yamaha Audio... • Answered on Jul 20, 2020
Yamaha HTR 5930 - AV receiver - 5.1 channel Logo
2 questions posted
Top Yamaha Audio Players & Recorders Experts
Will
Level 1 Expert
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
yamaha htr 5930 shuts off after about 4
  • Audio Players & Recorders
