20 Most Recent Bosch SHU4006 Dishwasher Questions & Answers
Suggest you test the intake water valve during operation to determine if the machine is "telling" the valve to work. If there is no electricity flowing, it could be a bad control, or perhaps another part is preventing the control from sending the signal, for example, the door switch is saying "the door is open" hence it cannot spray water. Give a try to "Sears Parts Direct" with your make and model and you will see a blow -up of all the parts, may help you find the float switch location, I hope. God bless your efforts.
Bosch SHU4006... • Answered on Dec 08, 2015
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
Bosch SHU4006... • Answered on Apr 19, 2014
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Bosch SHU4006... • Answered on Sep 15, 2012
If you have power to water valve when it is supposed to fill yet doesn't the water valve is bad, as long as their is a good water supply to the valve. Sometimes espically if it has one of those flexible stainless steel braided hoses something in cabinet could have pinched it,
Good luck,i hope this helps
Gene
Bosch SHU4006... • Answered on Aug 01, 2011
Hi
This issue is either due to short circuit or moisture on the control board. You'll need to access the control panel by removing the front panel from the dishwasher. Part#1A is the control module.
To remove the front panel---
1.Remove fascia panel by removing T-20 Torx inner door screws.
2.Disconnect wire harnesses from module after noting connector locations.
3.Pry out metal console tabs holding module to console.
4.Carefully pry back plastic tabs, then slide module from console.
Hope this helps... Please post back for further assistance.
Daniel
Bosch SHU4006... • Answered on Nov 25, 2010
First of all you must set the machine to a soft/quick wash and let the cycle run. During the process of the program check the voltage on the pump during the drain cycle. It is important that the controller unit supplies voltage to the pump. If power is presetn without a drain,it is evident that the pump is faulty. You must remove , set it up on desk to trail with external votage, clean or backflush , if not the pump must be changed unless a fulloverhauling is not sucessfull.
If there is no power to the drain pump, then it is the fault off the program controller unit. You will need to check on the controller for the absence of the power, fault in contacts, fault in the drive. Must use a good multimetter to trace the path of the triggered supply voltage to the pump. make sure that the voltage is not cut off in the wires to the drain-- possible line break.
Please go through these tips and check out. You have to do the voltage checks but have caution when checking all power points.
Bosch SHU4006... • Answered on Oct 07, 2010
Possible that the porgram controller is faulty and is shorted inside this drive.
you will need to remove and reset once again to make sure all connections are tight, if not the controller must be checked or swapped to confirm
Bosch SHU4006... • Answered on Sep 28, 2010
The timer switch micro- motor to be checked. Contact service provider.
Bosch SHU4006... • Answered on May 24, 2010
Drain problems are almost always going to be a clog. Disconnect the drain hose from the air gap vent at the sink top. Place a bucket under the hose and run the drain cycle. Unit should drain. If not, clog is either in drain hose or under the dishwasher's internal filter. Remove filter. Locate the item causing the clog and remove it. If nothing is found here, the problem will be in the air vent gap filter itself. Disconnect the other hose and remove the air vent gap from the sink. There's a small cap at the top of the filter. Press the clips in to remove the cap. Flush the unit with water or use a thin, long blade screwdriver to remove the debris.
Put it all back together and test again. You should be fine.
Bosch SHU4006... • Answered on Mar 20, 2010
THERMADOR .COM POST A 4 THUMBS UP FOR THIS INFO THANKS
Bosch SHU4006... • Answered on Feb 28, 2010
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Bosch SHU4006... • Answered on May 31, 2009
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Bosch SHU4006... • Answered on Nov 07, 2007
It appears that your model is probably SHEM63W52N/01 Bosch cunningly hide the heater inside the pump housing and sell the pump and heater as one unit! Having said that, the heater usually works or it doesn't. When it comes on is controlled by a control unit, another expensive part. I was looking for a relay, but there isn't one. The spray arms move by the water pressure making them spin. First of all I would remove them and check all the holes for blockages. Replace them and make sure they spin well by hand. If you are inclined, strip the pump and make sure is is clear of blockages and the impeller spins well. Check the continuity of the heater element. https://www.appliancepartspros.com/parts-for-bosch-shem63w52n-01.html ..
Bosch... • Answered on Mar 28, 2021
These handles are often mounted from the back of the door. You might have to strip down the whole door to replace the old handle
Bosch... • Answered on Mar 17, 2021
Dishwashers Logo
18 questions posted
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Bosch Dishwashers
  • Bosch Dishwashers
Most Popular Question
bosch dishwasher stuck
  • Dishwashers
